Question about Garden
How do I load nails into CH nailer DJ0808? I can get staples in fine but nails don't seem to fit. ANy help appreciated.
rowdy45176
  • 2176 Answers
SOURCE: how do I load nails in Stanley powershot staple/brad nails
you can try and go to Stanleytools.com and get to their knowledge base of FAQ or they have a direct way to contact the company for the information you need. I was on their site and have seen better to help the end user.
Posted on Dec 30, 2008
rowdy45176
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
  • 288 Answers
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
Posted on Dec 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: how do you load nails?
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft.
Flip the tool over on it’s back.
Insert the staples, (points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 06, 2010
CaptAdams35
  • 28 Answers
SOURCE: how do you load nails in stanley tr250 staple and
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
Posted on Mar 09, 2010
Harbor freight nailguns
Any nail or staple with the same specs can be used. For finish nails it would be the gauge (15, 16, and 18 being the most popular sizes) and angle (if angled and not straight sticks of nails), for staples it would be wire gauge and crown width, for nails it would be the nail diameter (.090, .099, .131 are examples), the nail angle in degrees (NOT counting a roofing nailer, some other coil nailers us slightly angled nails such as 15 degrees) and this is very important with a stick nailer as there are a few different ones out there, and of course max length your tool will shoot of any given fastener. Most boxes of nails/staples will have the specs you need printed on them somewhere and the owners manual will usually contain the same info.
Apr 21, 2012 | Tools & Hardware - Others
I just bought a powershot 5700M Staple and Nail tool. I could find how/where to load the nails. Can you help me?
Hello, W/D here.
I'm not exactly familiar with your model, but have several others, and they resemble yours, so please take these directions as "generic".
Open the fill slide as if putting staples in the machine, making sure that all of the staples have been removed. Insert instead the brads down one staple channel. On my stapler/nailers it is the left channel, facing the gun from the rear. Look carefully on the sides of the gun and the ends as , usually, there is some indication of which channel to use, and you rs may well be the other side. Load and test the gun on some scrap wood. If necessary, change channels and try the other side.
Best regards, -- W/D--
Mar 03, 2011 | Powershot Tool Company PowerShot 5700KB...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
How to Load?
By looking at the picture it seems you have a framing nail gun, you can't load staples in it!!
Apr 22, 2010 | Porter Cable FR350A Factory Reconditioned...
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
Trouble finding 3 1/2 clipped head nails 34 degrees
You can use the same nails that are used for these nailers: Porter Cable FC 350A, Hitachi NR83AA2, Senco FramePro 701XP, 751XP ,Ridgid R350CHA, DeWalt D51822, D51823, and Paslode F-3505. Make sure you purchase the correct shank nail. Nail length should be 2"- 3 1/2" and the shank should be .113" - .131". I have purchased nails for my FC350 at Home Depot and they are relatively inexpensive. Though you have to buy a case of like 2000 or 4000. The brand of nail is Grip Rite that I purchased. Any questions please post.
Oct 06, 2009 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
My stanley model tr 250 seems to be jammed up and won't load staples
Generic comment.
There should be a pin or a screw (probably with a locking nut) on the business end of this machine. Find it, remove it and the track should pull down allowing you to clear the jam.
I hope this helps
a
Sep 27, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
Can you help with loading staples into a stanley sharpsshooter T50 staple gun
Look at rear handle bottom, Push in then pull out,load. Please rate. Thanks
Jan 25, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
Staple,nail gun, how do i install the nail properly
SHOULD BE A SPRING LOADED TAB LOCATED USUALLY AT THE REAR OF THE GUN. PRESS IN THEN DOWN AND SOULD POP OUT SO YOU CAN LOAD.
PLEASE RATE
THANKS
Nov 13, 2008 | Tools & Hardware - Others
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
