Question about Compaq Presario R3000 Notebook
Will not turn on at all
When I plug it in, the power led comes on, but when I press the power button....nothing, no fan, lights or anything. Is there a fuse onboard or reset button or something?
Mark
  • chester50014 May 06, 2008
    Computer will not turn on and no led light comes on.
I also have no lights, no action at all,
after taking the unit apart i've noticed a number of little red buttons hopefully one is for some sort of charging system reset, i talked to compaq and they wouldn't tell me any thing about the buttons. however i've found a couple sites clamming to have service manuals for free.
im looking into that now
Posted on Jul 05, 2008
Does not switch on but power on light is on
I would remove the battery, power supply, RAM and hard drive. Plug the power supply in and see what happens when the power button is pressed. If nothing, there is a motherboard issue, possibly a GPU error. If it comes to life, re assemble bit by bit until the culprit is found.
Jan 14, 2014 | Computers & Internet
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
SP 6000/PS6000E-207PK-EN Will not fire up. If press start, then LEDs flash Orange (1st left) 5 times then 2, then 1 and then repeats. 3rd LED (green) stays on. If battery is removed, start button pressed...
You got some short on board, You need techguy. Or possible Bios flash, Remove the Harddisk and press the power button.
If nothing change, Remove power, battery, cd rom, Hdd, memory.
Then put one stick of memory, power up, see anything comes up.If does, power off, put the other memory plug in power, fire up.
If does ok. Then plug off, and put hdd without CD rom. see if it did work.
If none is worked as I say you have short or CPU fan is not functioning.
Goodluck.
JMC
Aug 17, 2009 | Toshiba Computers & Internet
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Laptop won't power on
change the color converter card.
Mar 09, 2009 | Toshiba Tecra A7-S712 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Compaq Presario R3000 Notebook Logo
152 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
