Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer keeps shuting off in the spin cycle and the code ob shows up.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error ob indicates off balance, if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an “ob” for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load. Press STOP/CANCEL to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 24, 2010
  • mbaynard Sep 01, 2010
    Rylee,
    Thank you for your comment, but this OB is coming on with nothing in the machine. It will not go into a spin cycle without shuting down, even empty. Any other ideas?
    Michael
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer had an error code of OB. Is this Off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
May 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Gives codes ld and ob when in the spin cycle and wont complete the cycle even when load is redistributed. had a repairman here and he replaced an electrical part that was spendy. Still doesn't work....
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#$%
Nov 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Whirlpool Calypso GVW9959K Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
