FixYa.com
Tags:
Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell (by 2 users)
posted by justmama on May 04, 2008
how do I check the hoses in the arm for clogging?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bunnieman, posted on May 13, 2008
I too have the problem of the little red thing not turning and the water will no dispense from the wand or the base. I tried the suggested solution of cleaning the tubes by the heater but could not get to that section. I took every screw I could find out of the handle and could not get into the bottom section by the heater. I took out two screws on the back but could find none on the front. Does it help to use very hot water to start with?
Solution #1
posted on May 09, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 87%, 975 votes
Do you mean the handle? If so, there are 2 screws and nuts holding the top part of the handle on, remove these then pull off the top part. Then on the back, near the bottom, are 2 holes that go in aways and there is a screw in each one, remove them and the two halves of the handle will come apart and you can get to the heater and lines.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
