Question about Mitsubishi WS-55859 55" Rear Projection Television
My Mitsubishi Model ws-55859 Wont turn on. The timer light just flashes. Is ther a common fix?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 23, 2010
  • john2000 Feb 22, 2011
    Looks like with everything I'm reading I;m in the same boat. 2,2 disconnected front panel still the same. Please send me the info on where to ge the kit, both caps and fuses and the instructions and I will give you only great feedback..
Green blinking light ws-55859 tv wont turn on. We have uplugged....still nothing
The blinking light is what's known as the blink code. The blink code tells you what the problem is. To find out what it means, count the number of times the light flashes then Google your make and model with the words blink code added to the end. This will show you links to sites that will tell you what the problem is.
Sep 11, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Green light flashing on timer. tv wont power up..just bought this house. wtv was left behind. i was told it works but i cant turn it on
Thats a common problem if the sets left unplugged or without power the DM caps drain and then wont charge when the power is restored. Its a easy fix usually just replace the DM caps. You can get the Mitsunbishi repair kit called the WS55859 DM repair kit from www.tvrepairworld.com which has the upgraded replacement caps and the CD with repair instructions.
Jun 14, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Timer light will not stop flashing and tv wont turn on
very easy repair caused by failed DM capacitors. You can get the WS55859 DM repair kit from www.tvrepairworld.com which contains the upgraded capacitors and the CD with repair instructions.
Mar 03, 2011 | Mitsubishi WS-55859 55" Rear Projection...
I have a mitsubishi ws 55859 that has a green blinking light. and the TV wont turn on. Don't know how to fix it
The convergence board or the verticle is bad. needs professional repairs can cost anywhere from $ 180 to 350. Check it out at www.fixurtvs.com.
Feb 22, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
Jul 06, 2009 | Mitsubishi WS-55859 55" Rear Projection...
55859 withh flashing timer
Greetings,
Chances are very good that this type of problem is a cold solder joint on one of the circuit boards. Unless you know exactly what you are doing don't attempt to fix this type of problem. The circuit boards in rear projections TV can carry enough voltage to kill you even if the set is not plugged in. Contact a repair shop and get an estimate. Then do a repair vs. new flat panel replacement comparison.
Hope this will put the right perspective on your problem.
Dec 10, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
1,032 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
