Question about Stanley Bostitch Coil Framing Nailer
I have an n80sb air is coming out around the trigger? Thanks
  • 4,234 Answers
This is usually indicative of a defective trigger. This can be replaced. First though, try checking all the Orings. If the unit has not completed the cycle to the "ready" position, there could be an air leak. Please visit the site listed below to get a diagram of the entire unit with replacement part numbers etc. the diagram should assit you in dis-assembling the unit to clean and re-oil it.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CLyNls3l0KMCFeoD5QodWw4_wA
Posted on Aug 23, 2010
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
I have a Stanley Bostitch N80SB with the sequential trip kit. I have installed a new trigger valve assembly, and the unit now holds air pressure, but the trigger will not activate the plunger. I can...
The safety foot assembly pushes up on inner trigger lever which in turn pushes on the trigger valve. If the trigger valve firing pin is slightly shorter than the old trigger valve, or the inner lever is worn from use, the inner lever will not push the trigger pin all the way in. Examine the trigger and the roll pin that holds the trigger for wear and check that the safety is pushing up on the inner lever. If the trigger is worn replace or repair with metal type epoxy filling in worn spots and use a new roll pin.
Aug 18, 2011 | Stanley Air Tools & Compressors
I have a n80sb-1 bostich nail gun. How do you remove the tva-11 valve once the roll pins are out. Thanks
There are a couple ways. The easiest is to use an air blower at a very low pressure such as 10psi. Put the nose of the blow gun at the end of the nailer where the air hose connecting stem is and blow into it. The valve will pop right out. Another way is to carefully grasp the trigger valve stem with a pair of needle nose pliers and pull. Just be careful if it has the plastic valve pin as you can damage it. Later models use a metal pin. You can also use a small pick such as a dental pick and get the valve out by prying it at the rear of the housing.
Jul 15, 2011 | Air Tools & Compressors
I have a n80sb have bought two tiggers and put in it av11 they both leak from the outside of the tigger what do i do
forget the out side trigger levers,you need the trigger valve assembly,its inexpensive go to your nearest bostich dealer
Dec 28, 2010 | Stanley Bostitch F21PL Nailer
I'm looking for a picture how to remove the trigger assembly for my bostitch nail gun model N80SB
You can go to Stanley Bostitch.com and look at a breakdown. you can also unplug the air line and you will find 2 roll pins holding the trigger valve in place and 1 holding the trigger itself, remove all of them and then FOLLOW closely, wrap a shop rag around the handle area of the trigger to completely encase it. Then holding back on the release portion of your air hose so you can pull it off immediately, push it on the adaptor and you will hear a POP REMOVE immediately and then remove rag and the trigger should be in it. If you are uncomfortable doing this don't even attempt, its not that hard just take your time. Let me know if I can help further and if I have helped you would you please rate my reply accordingly and thank you.
Jul 04, 2009 | Stanley Bostitch BT200K
Stanley Framing Nailer Leaking Air Around Trigger
Your tva11 valve can be repaired easily if you have a source for orings. I purchase orings from several companies including lowes (in plumbing dept sold in 10 pack for about dollar), www.grainger.com (oring kit metric, cost about $10) harbor freight (oring kit about $5), also orings are sold by size at bearing companies. I have repaired many of these valves by just cleaning debris and lubing with silicone paste (sold at lowes in plumbing dept used for lubing faucet orings). To attempt repair of valve, remove nails, remove roll pin that holds trigger (3mm) to expose tva11 valve. Mark position of valve in body of gun because the retaining pins fit thru an indention in the valve. Next remove roll pin/s that hold tva11 valve, they are just above the valve in the body of the gun(3mm x 30mm). You will need to apply air pressure to gun to remove the valve, however use heavy glove to catch valve because it can come out with force. (try lowering air pressure to gun for this procedure. With valve in hand, use marker to mark position of inner part in relation to outer, remove the two pins that hold valve together. Push out the inner cylinder and look at the middle oring(usually the problem, could be loose or cut) , If cut or loose replace and lube with silicone paste and re-assemble. Check outer orings for nicks, replace as necessary (usually good). Clean valve port, lube port, then re-install valve into gun and insert temporary retaining pin and test for leak. You should be good to go. Good luck and email if you have questions.
Mar 30, 2009 | Air Tools & Compressors
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
LEAKING BOSTITCH AIR NAILER
you probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Dec 26, 2008 | Air Tools & Compressors
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Stanley Bostitch Coil Framing Nailer Logo
235 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
