Question about Canon PIXMA MX850 Multifunction Printer
Printer shows error message u052 and will not allow any access to 'menus', 'settings' or 'reset' I have replaced ink cartridges and it works for about 20 minutes (printing 8 pages and copying 2 pages) before the error message appears
I have the same problem - after installing the firmware update fumx850win1030en
Posted on Oct 23, 2010
Pixma error message U052
Try holding down the Stop/Reset button on the top of the printer for approximately 10-20 sec. It should start to print. If not try a different cartridge.
Jan 13, 2013 | HP Canon Mg5250 Pixma Pgi 525 Cli 526 Ink...
Error message U052
U051 indicates an ink cartridge that cannot be recognised by the printer. Sadly you cannot use your printer while this error remains.
I would advise the following:
-Remove the problem cartridge from the printer
-Wipe the gold contacts on the front of the cartridge with a piece of non fibrous tissue (like kitchen tissue).
-Re-install the cartridge.
If the error remains it is likely that there is a genuine problem with the cartridge. So I would advise getting in touch with whoever you purchased the cartridge from to arrange a replacement.
Sep 04, 2012 | Canon Office Equipment & Supplies
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
How do I remove the print head from my Canon MP810 printer for a clean? :o)
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Jan 11, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Message in display: Cartridge error refer to
Here are the basic reset instructions. See also here.
Please make sure you followed these instructions to change the cartridge, and the alignment was completed. (see also here)
It may be necessary to clean the cartridge contacts as described here.
If that does not help, you may also access additional online support for your printer here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Officejet 4315v All-In-One InkJet...
Cannon MP600 error message U052
Hello all, I have had an MP600 for a few years now, and after paying about £50-£60 a set of inks i decided to use compatible ones and i also spent £20.00 on a ink resetter from Sudhaus http://www.patronenhandel.de/shop/en/Redsetter/MP-Serie/MP-600/mit-Refill-Set
After about a year of owning the MP600 i got the dreaded U052 error, so i went back to genuine inks, however this did not clear the error. i then decided to telephone Canon and they advised me to clean the print head thoroughly. If you look at the print head there is a white plate with 2 screws either side, i rmoved that CAREFULLY and cleaned behind it, i reinstalled everything back to normal and 2 years later i am still running perfect with no issues what so ever...I'm not sure what resolved the issue but i now refill my genuine cartridges myself and reset the chip with the Sudhaus resetter. To refill your cartridge use the tube inside the genuine ink cartridge DO NOT refill from the top, you will see the 2 arrows on the GENUINE ink cartridge pierce between there and use a long syringe to refill.
Hope this helps people in the future.
Jan 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MX850 Multifunction Printer Logo
894 people viewed this question
old marine
old marine
