Question about Jensen XCH6RF 6-Disc CD Changer
UCH6006 stereo cd changer (Jensen)
What do I hook the power wire too, and what do I hook the yellow wire too?
    Problem Solver:
  • 4 Answers
Your red wire goes to your aux ignision and also your yellow as they are both power wires
Posted on May 07, 2008
Yellow wire; what does it connect to? Blue Wire; what does it connect to as I don't have a power antena. Is there a way to wire the unit so that the key needs to be on to play the 'radio'?
If you do not have a power antenna you will not hook anything to the blue wire, if you have an amp you can use the blue wire for a remote turn on for the amp, otherwise leave it unhooked and tape the end so as not to cause a short. The yellow wire should be your constant power and the red wire should be your key on power (or vise versa) Not sure what radio you have, but you should be able to google your model number and get a diagram for it. You will hook either the red or the yellow to constant power to save your station and clock settings, and the other hook to a keyed power source so the radio will work when you turn the key to acc or on positions.
May 18, 2015 | Cars & Trucks
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Im hooking up a pioneer car stero in a 2001 chevy cavalier. I purchased a chevy plug n play wire harness, and I hooked up all the wires (color coded) and plug it in, but no power, I have A ground and a...
your adapter should be color coded to the pioneer wiring, orange, red and yellow are power feeds for igntion, 12 key and lighting, veryify voltage on the orange and red wiring to the radion with key on, the yellow is for radio lighting with parking or headlight operation, some adapaters may not have all the wiring and you may have to splice around the adapter.
Jan 03, 2018 | Car Audio & Video
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
I have an after market pioneer car stereo and not sure how to hook the red,yellow and blue with the stripe, to the wire harness with orange lummination and orange dimmer negative,yellow batt. and blue i...
red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Jensen XCH6RF 6-Disc CD Changer Logo
111 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
