Question about Princeton Digital VL1916 19" LCD Monitor
Stuck in power save mode
My Princeton 19" LCD mdl VL193 is stuck in "power save mode" and therefore unusable. What can I do besides taking it back to Costco?
  • 1 more comment
  • mmgwhite May 07, 2008
    The monitor won't turn on. I cannot use the computer without it. I cant get any of the buttons on the monitor to work. Therefore I cannot decide what input is selected.
  • Anonymous Jun 10, 2008
    I am unable to adjust the brightness and contrast on my monitor. If I hit the auto button it will brighten up for 4 seconds the go back.
  • Anonymous Oct 08, 2008
    I have the same problem. If I press the up arrow, it lights up file for a couple seconds and then goes blank. All other buttoms are unresponsive.
    Scholar:
  • 125 Answers
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
Posted on May 04, 2008
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
I have a Princeton VL193 monitor and recently in will just power down. It just shuts off. If I unplug it from the surge protector and plug it into the wall outlet it comes right back up. When I plug it...
Monitor is erratic in operation - Power supply issue. Sooner or later the anomaly will become permanent and it will not power on. Just be ready for the eventuality.
Sep 14, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have had the monitor plugged into my HP laptop. Suddenly, it showed a "Power Saving Mode" message on a blank screen. I have gone through my troubleshooting guide. The screen now shows my background...
Depending on which version of windows you have the directions may be slightly different but in the display settings check to see if it is set to extend the display or to duplicate the display both do very different things. Hopefully adjusting this will correct your issue.
May 31, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | Princeton Digital VL1916 19" LCD Monitor
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
Monitor stuck in power saving mode
If the monitor goes into power saving mode as soon as you turn your computer on then maybe your graphics card is only half-way in and not secured properly. I would first recommend plugging in a different monitor if you have one, if it doesn't get any signal either then read on. I had this issue, basically a couple screws need to be put back in because they have fallen out. The graphics card was only partially plugged in and the computer would run but not "communicate" with the monitor. If you are unsure how to do this then I recommend taking a trip to your nearest IT shop, the job takes only about 1 minute so you should have your computer back quickly. Hope this helps,
David
Feb 07, 2010 | Princeton Digital EO 900f (White) 19...
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
929 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
