Question about Mach Speed (S755) Motherboard
No video so the motherboard the viper 939 has no proprietary CRT connection so i went out and got a video card put it in still nothing how am i supposed to boot the computer up or load the drivers or ANYTHING if theres no screen for me to navigate with
    Guru:
  • 1,342 Answers
What kind of video card did you get?
Check this list
Some other things to check HERE
Posted on May 05, 2008
My old mother board a 939 socket took a dump i have gtx 285 evga video cards and x-fi fatality sound card im looking for a good bundle for this to go in to would like to stick with a asus board and...
Socket 939 Motherboards are pretty rare. Basically, if you find any socket 939 motherboard, the parts you have now should all fit precisely since there are only a few socket 939 motherboards right now on the market.
Here is one i found.
Mar 07, 2011 | ASUS A8N32-SLI Deluxe Motherboard
No display every thing seems fine
1) Have you tried a different monitor ?
2) Are your video drivers up to date ?
Jul 04, 2010 | Biostar TFORCE 6100-939 (890552604234)...
Video and sound hesitation playing DVDs or short video clips
The problem was screen resolution was set to high. When I set down 1024/768, the problem stopped.
Thanks for the answer.
Frank
May 19, 2009 | ASUS A8N-LA GeForce 6150 LE Socket 939...
Complience of motherboard and video card on new PC
remove the GFX and try onboard or try chainging ram slots...
Mar 14, 2009 | Evga e-GeForce 9800 GX2 DDR3 PCI-Express...
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Oct 15, 2007 | Mach Speed (S755) Motherboard
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop. Also assuming you bought the ram from the same place and is compatible with the board. Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual. The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip. That's not to say that the motherboard was'nt faulty in the first place.
Apr 18, 2007 | Mach Speed (S755) Motherboard
Mach Speed (S755) Motherboard Logo
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
