Question about Thermador REF30 Electric Kitchen Range
Two problems: Thermador REF30Q free standing range 1) The range controls have gradually faded and are now impossible to read making it impossible to set the temperature, timer and other controls. 2) and the oven does not turn off when the cancel button is pressed
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Thermador REF30Q free standing range 1) The range
Hi, W/D here.
You will need to replace the display. It is possible to troubleshoot the board, but that's a bit more labor intensive, and you'll need to check parts with a multi-mater, and know the required value for each.
Here's a link to Thermador parts. You will need your serial number to make sure that you are looking at parts for your series. Some parts in the same model have changed.
Best regards, --W/D--
Posted on Feb 09, 2011
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Digital readout blinks
Hello , I can help with this issue , When your display fades or flashes it is the first sign of your control board going out. The control powers your digital screen and they are very common to fail. If you have the model with the controls in the back top of unit against the wall it is basic to replace the board yourself , if you have the controls in the front of the unit it is more advanced to get into but is still possible. [controls meaning screen & burner knobs.]
A good place to order is sears parts. be sure to use your model off the oven its self. Please let meknow if you have anymore questions. Phil
Dec 31, 2008 | Maytag MES5752BAS Stainless Steel Electric...
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Open Questions:
See all Thermador REF30 Electric Kitchen Range Questions
Thermador REF30 Electric Kitchen Range Logo
60 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
