Question about Kenmore Kitchen Ranges
My kenmore gas range oven doesn't warm at all
  • Kenmore Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 23, 2010
My Kenmore GAs RAnge Oven doesn't light up right away...lots of gas smell. The burners on top work though
check the gas range in the oven. clean the top apparently the ignitor isn,t working properly. I cleaned mine and once it lit I let it burn a while.
Aug 22, 2011 | Kenmore Kitchen Ranges
I have a kenmore oven and the bottom wont heat it get voltage the timer and clock works it clicks off and on like its trying to heat up but does nothing
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Apr 08, 2011 | Kenmore 91072 / 91074 / 91079 Electric...
Oven takes way too long to ignite and or warm to temp
Oven not Working or
Oven not Heating
heatman101
Feb 11, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
The warming draw works, the stove top works, but the oven itself will not warm. The electronic panel says the oven is on and heating, but the oven does not get hot.
Sorry to read about your problem, I hope this helps you out.
you have a defective temp control
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Kenmore range [gas]and the oven wont come on The pilot light is lit..since I cleaned it it has acted funny,comes on sometimes, makes me think it is clogged up what can I do to ck. this out
Take a Q-Tip and carefully clean around the orifice where the flame usually is. If the pilot is not successfully warming the thermo couple the safety will not allow the control to let gas by for ignition.
Dec 23, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
When turning on oven it says f3 or f13 err and i can erase it
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Self cleaning oven instructions
you can google it or just push the clean button and it will most likely default to 3 hours and all you have to do is push start and after it is done wipe out the ashes with warm soapy water DO NOT USE OVEN CLEANER as this will destroy the finish of the self clean cavity
Nov 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kenmore warm and ready draw self cleaning oven
Give me the complete model # from the sticker on the range and I can help you with this.
Nov 11, 2007 | Kenmore 33169 Gas Single Oven
Kitchen Ranges Logo
51 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
