Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Can't get broken hex bit out - Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
  • 4 Answers
If you have a drill with a hex bit head, and you have broken off a bit with the hex end remaining in the drill do the following:
find a nail with the same diameter of the hex remaining in the drill, put some super glue, or epoxy on the head of the nail, place the nail head against the hex in the drill, wait for super glue, or epoxy to set, pull or push the collet on the hex head of the drill, then pull the hex out of the head. frank t.
Posted on Mar 19, 2014
  • 2,176 Answers
What you need to do is remove the quick release mechanism. there is a retaining ring DO NOT STRETCH then a small flat washer and spring lift the collar and there are usually 2 small steel balls. then using a magnet you should be able to remove bit. this works only if the shank on the bit is not twisted.
Posted on Aug 26, 2010
How do you remove the idler pulley on a 99 regal? socket not a bolt?
instead of using AF size bits(1/4") try using metric bits as they come in 1/2mm sizes
Jan 31, 2015 | 1999 Buick Regal
Tip
How to remove a broken bolt the easy way...
Say you have snapped the head off a rusty bolt on the car, its infuriating!
But, there is a fantastic tip from a mechanical engineer that works every time, and is easy to do!
Lets assume the bolt is a 10mm exhaust stud or similar, take a 4mm drill bit (sharp one) and a 4mm hex (allen) key, (especially a t-bar type or socket mounted one) - drill a pilot hole right down into the bolt with the 4mm drill, as far as you can without snapping the drill bit in the bolt!!! Use light pressure, a sharp drill bit and let the drill do the work, and keep it straight....then when you pull the drill out, tap the hex key into the hole you made with a hammer, get it in as far as you can, it will be a tight fit as the 4mm hex key measures 4mm from flat to flat across it, and the corners of each flat are slightly more than that so it bites very well into the bolt, spray plenty of release fluid or wd40 around the exposed bolt thread to help loosen it, leave for 10 minutes if rusty, then turn the hex key with either a socket and wrench or the t-handle on it, and it will turn the bolt without slipping!
And hex keys are VERY VERY strong, much stronger than a bolt as they are tempered high tensile steel - the bolt will unscrew with ease! Forget useless screw and bolt extractors! And simply pick a drill size that gives a decent hole leaving some metal at the sides of the bolt but not too small a size, and keep the hex key to the same size in mm as the drill you use, if you made a mistake just go up a size or 2 on both drill bit and hex key and you get another try, but should not need it!
on Jan 14, 2010 | Ford F-150 Cars & Trucks
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
I'am trying to change my front pads on my 92 taurus. but i could not figure out how to get the caliper off to put the new pads on. could you tell me what to do?
You need a socket with an allen/hex bit. Not sure about the size of the hex bit you will have to figure that out yourself. There are 2 scews holding the on calipers.
Heres what they look like:
http://www.autozone.com/autozone/parts/Motormite-Brake-Caliper-Bolt-Guide-Pin/1992-Ford-Taurus/_/N-ix2afZ8knjf?counter=2&itemIdentifier=102943_172605_15907_
They are on the back of the caliper toward the engine, find the proper size hex socket. They sale a set of the sockets at Autozone for around $10, 3/8 inch drive. Thats the best way to go.
Heres what you need:
http://www.autozone.com/autozone/accessories/Duralast-5-pcs-3-8-in-S-2-square-drive-hex-bit-set/_/N-25f3?counter=0&filterByKeyWord=hex+bit&fromString=search&itemIdentifier=947316_0_0_
Sep 18, 2011 | 1992 Ford Taurus
My dw056 breaks bits can you change the hammer to a 1/4" or 3/8" hammer they look the same on the manual
in order to make the 1/4" hex drive impact drive 1/4" or 3/8" sockets, you need a 1/4" hex adapter for sockets.
They are available at most hardware stores. While i've broken several sockets, and many screwdriver bits, I've never had an issue with with the socket adapters.
You can also get an adapter that gives you a chuck like a conventional drill.
If you've been working them hard, it's not a bad idea to remove them, and put them back in. this reduces the chance of getting the bit stuck from the repeated impact.
As far as changing the chuck of the unit to another one, i'm not sure if it's possible.
Help me support children’s cancer research CLICK HERE!
Mar 08, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Not sure if what I think are hex screws are actually that
Assuming that the bit head is flush with or recessed into the hex slot, I think it depends on how big the hex slot is, but if it's a clean break, you could use a strong glue (like krazy clue) or a cement (like PC7) and glue something to the bit (or the screw itself if you have a replacement) and then 'wiggle' the bit out. Often you can unstick the broken tip by applying pressure in the opposite direction that was applied when it broke just to free it up. You could drill into the bit just enough to secure a stronghold for gluing, say, the end of a coat-hanger into the hole.
Jul 21, 2009 | 1997 Saturn SL
Hex on drain plug is broken
use a reversed drill bit or you can get a screwdriver red hot and stick it into the plug and then let it cool into there
May 25, 2009 | 1998 Ford Windstar
Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Apr 10, 2009 | Ryobi 18v Variable Speed Impact Driver...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
218 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
