Question about Nortel 1140E
How do you turn off ringers for a phone that has multiple lines?
How do you turn the ringer on/off on aatt 993 2 line phone
If you mean the AT&T 993 two-line speakerphone, you can adjust the ringer volume for each line when the phone is not in use. To increase the ringer volume on the primary line (if set), press the Volume Up arrow. To decrease the ringer volume, press the down arrow. There are 8 different volume levels available for the ringer. The Volume Up/Down buttons are below the * and 0 keys.
To adjust the ringer volume on the secondary line, press that line button (between the Conference and Hold buttons) and then press the Volume Up or Down buttons as needed. (If you haven't programmed a primary line, press a Line button and adjust that line's ring volume before pressing the other Line button. Then adjust the volume for that Line.)
I hope this helps. These directions are shown on page 32 of the manual. AT&T currently has the manual here : https://att.vtp-media.com/ecp/documents/product_Product/227/UserManual/5596/993_manual_i14.pdf . To find this manual or other AT&T phone manuals, start here: https://telephones.att.com/product-support/manuals .
Mar 27, 2018 | Lands Phones
How do I reenable the ringer on my ATT 993 phone. The phone does not ring
Make sure to look on the phone itself, and see if there might be a button on the unit, or base station, that turns the ringer on/off.
Feb 21, 2015 | AT&T High Quality ATT 993 2 LINE...
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
Mar 06, 2012 | AT&T 972 Two-Line Memory phone
Ringer is off and I want it on
If there is a volume rocker on this particular device. Press the upper vertical button multiple times until it turns the ringer on.
Hope this helps-
J.Sper
Mar 06, 2011 | Cell Phones
My panasonic phones do not ring when an incoming call is coming in. There is a dialling tone on all 3 handsets and they all appear to be working ok
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
Oct 19, 2010 | Panasonic (KX-TG1032S) Phone
Ringer off on line 2
To turn the ringer off (or on)
press the conf/ function key,
scroll to "ringer volume" using the up and down arrow keysand press the forward arrow key
press the down arrow key for line 1 and the up arrow key for line 2
select the desired ringer volume by pressing the up and down arrow keys or press the down arrow repeatedly till the screen says "ringer off?"
press the save key (right soft key) you will recieve a conformation beep.
you can exit programming mode by pressing the off key.
Jul 20, 2010 | Panasonic KX-TG2740 Cordless Phone
Lucent 854 phone, how do we turn up the ringer?
To Adjust Ringer Volume:
1) Press CONF, then using the dialpad press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2) Press one of the VOLUME buttons to increase or decrease the ringer volume.
To Turn the Ringer Off
1) Press CONF
2) Use the dialpad, press 1, 2, 3, or 4 to indicate which line you want to adjust
3) Press the down VOLUME until you no longer hear a tone.
Feb 28, 2009 | Lucent Lands Phones
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Phone Doesn't Ring
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on. In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Nortel 1140E Logo
143 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
