Question about Soundstorm Laboratories SD870TS Car Video Player
What is the parking brake bypass code or method i can hear the sound but no picture i have the unit in my boat
  • 57 Answers
Very simple ground the e brake wire that is all you also may need to run a switch in between where you can reach it cause somtimes decks need to be ungrounded(e brake wire) then re grounded when you turn it off then back on but yours shoud just be able to ground to the back of the stereo with the aftermarket deck ground(black)
plz let e now ifyou need further help
Kieran
Posted on Aug 25, 2010
Shift lever will not move out of park. Engine is running, seat belt fastened, parking brake released, all doors hood and trunk closed, foot firmly on brake pedal.When the button on the side of the shifter...
you should hear a click from the solenoid when you apply the brakes. If your brake lights don't work, your shift lock release won't either. There is a bypass method for emergencies in your owner manual. Check fuse for brake lights. And switch on brake pedal
Nov 06, 2011 | 2000 Saturn Ls 4dr Sedan
IVA-D106 Car DVD Player: no picture on screen while dvd is playing...
Im guessing that if you can hear sound but have no picture and this is newly installed that your unit is wired to your parking brake as a safety feature. You need to disconnect it and connect the wire to the radio ground to bypass it.
May 18, 2010 | Alpine IVA-D106 Car DVD Player
How to bypass the ebreak with the vm9313 model? Is there any codes or anything?
Hi megan
Although i have some reservation,i`ll assume your car does`nt have the parking brake wire so here`s the answer to your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Warning; use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
May 05, 2010 | Jensen VM9410 Car DVD Player
I just bought a dual xdvd9101 indash dvd player and cant get the brake bypass to work
However, some units use different methods. Some require seeing a pulse (i.e., power-ground-power-ground-etc.), resulting in the annoying need of pushing the e-brake a few times before your video will pop up. This can generally be recreated by using a 3-prong switch (you can get one at AutoZone). Connect it backwards -- the ground to power, power to ground, and the "Load" to the Parking Brake wire on the back of the radio. Flip the switch back and forth a few times and sometimes the video will pop up.
Some fancier units cannot be cheated. They use an internal gyro mechanism that detects movement.
Some even feature bypass codes. By pressing a certain combination of buttons on the remote then entering in a code it will permanently allow video.
Be good.
Dual DVD
Play Dvd for few seconds until you hear sound
Press Stop Twice
Then enter on remote 26604 the press enter
Nov 15, 2009 | Car Audio & Video
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Dual XDVD710 Car Video Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Sep 13, 2007 | Dual XDVD8181 Car Video Player
Soundstorm Laboratories SD870TS Car Video Player Logo
116 people viewed this question
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
