Question about Garden
Everything seems to be in order with it but it still cuts uneven
  • 395 Answers
The chain has probably been sharpened incorrectly. Take it to a shop that does chainsaw sharpening. They should be able to correct it but you may have to buy a new chain if it is too badly worn.
Posted on Aug 24, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
I have a 2016 x350 with a 48in accu deck and it's cutting uneven and I'll readjust it and it seems to go back to cutting uneven
Many people overlook the very first thing which must be checked for an uneven cut:-- proper inflation of tires. It's got to be either that or perhaps a slightly bent blade - or both. Otherwise, you've got something going on with your deck leveling process. I carry a small level with my mower and DR brush mower so I know I get accurate oil checks and also so I can place them in a dead level position to check oil and tire presure. Start at the bottom and work your way up. One more thing: you could have a very slow leak. If you haven't done so, get some slime and put in all your tires on all your lawn equipment. Amazing stuff.
May 20, 2016 | Garden
Why is mower cutting one sided
Possible issues:
Mower deck not level
one of the blades are bent
the spindle isn't square to the deck or the deck itself is bent
Jul 29, 2014 | John Deere Garden
The cutting deck is so unstable & the belt drive
For the deck,they do move it allows them to cut evenly on uneven surfaces.Lower the deck and inspect everything on top of the deck.These mowers have several arms to hold it in place.Make sure none are disconnected,or have broken clips.Make sure to wiggle each of the arms,some times they can fall in a position so that it looks like that is where it belongs.
As for the drive belt.Just keep the mower out of the weather as best as you can.Feel the pulleys for burs,and make sure there is no debris hanging that may be scrapping the belt.
May 14, 2011 | Troy Garden
The mower is not cutting even. we changed the blades and leveled the deck but can not seem to fix the problem
Everything sounds and looks good but the cut is uneven. I would think the only possibilities are a freewheeling blade, or an upside down blade. Neither situation is rare. If neither of those is possible I think I would set the whole thing up on jack stands and make sure nothing is going akilter in the mechanism which raises and lowers the deck, one side could be hung up.
Aug 04, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My zero turn mower's deck was knocked off. I put
if it got knocked off, i'd guess it hit something pretty darn hard. i'd check first for bent blade[s], then bent or broken mandrels
Aug 23, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
