Question about Maytag M7DH65B2A Dehumidifier
Water started to fill up inside the unit around the condenser and leak out the bottom. Not sure where to go from here. Any help would be appreciated.
  • 1 more comment
  • jcoleman676 Aug 23, 2010
    I have my unit set up to automatically drain so the float switch dose not come into play. Also checked the drain and it is clear.
    Thank's for you help
    Have my unit hooked up to auto drain so switch dosen't come into play. Checked drain and it is clear.
    Thanks for your help
  • jcoleman676 Aug 24, 2010
    I have the auto drain hooked up so the pan or float switch does not come into play. There is no obstruction in the hose or tube that connects inside unit.
    Thanks for your help.
  • 2,841 Answers
Have you checked to see if the drain nozzle is directly over the collection tank where the water can go there instead of on the floor? Is the collection tank fully installed and not cocked sideways? Is there are hole in the collection tank? If you are using an external drain hose, is the gasket at the connection in good shape and is the connection tight? Is the drain hose lower than the connection at the unit in all places. One part of the drain hose higher than the unit and it will not drain. Are you emptying the collection tank regularly? Make sure the drain is clear of any obstructions and the water is flowing into the tank as it should if you are not using an external drain.
Posted on Aug 24, 2010
  • 2,019 Answers
It is to be expected that a dehumidifier would produce water.
It is supposed to condense on the cold evaporator and drip down into the pan that you drain.
So it appears to me you are saying that it is not dripping down into the pan. Which means either you are not draining the pan as you should, or there is something preventing water from getting into the pan for you to drain. Which is it?
    Genius:
  • 1,478 Answers
Many dehumidifiers have a float switch that prevents the unit from spilling over with the water that has been drawn out of the air. Sometimes this switch goes bad and must be replaced. If your dehumidifier is overflowing, you can test the overflow prevention switch with a volt-ohm meter.
1) Unplug the dehumidifier and remove the switch.
2) Disconnect the leads and clip the leads to the terminals on the switch.
3) Check the pan or reservoir and empty it if necessary, or make sure the drain isn’t clogged.
4) Straighten any kinks or bends in the unit’s hose.
5) Set a volt-ohm meter to the RX1 scale (or to K- or resistance on a digital meter) and depress the bar or trip lever on the switch. If the meter’s needle shows no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Take care.
Posted on Aug 23, 2010
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
This is a D945E - when on continous drain, condensation runs out of the drain but also leaks all around the unit
You need to check the position of the drain tray, it could be tilted and fill up before reaching the drain pipe
Jul 11, 2011 | Amana Dehumidifiers
I have a Goldstar 305 unit and have been very happy with it for 4 or 5 years. Three days ago I noticed it was running very loudly and for much longer than it usually takes to fill the bucket. The bucket...
The problem you're having sound like the drain tubing to the bucket is partially clogged. But, it is resolvable. Here's what you'll need to do.
Turn the unit OFF & unplug it from the wall. Remove the bucket and at the inside top of the bucket holder, you will see a hole or a tube that drains water into the bucket.
Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in the drain hole or tube. Carefully insert the Zip Tie and work it in, until you reach a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or your run out of usable Zip Tie. Then, slowly remove the Zip Tie while rotating (twisting) it. This will dislodge any clogs. Once you start nearing the end of the inserted tip, be prepared for some water to follow.
After completing the above, reinstall the bucket, making sure that it fits "squarely" from top to bottom into the bucket holder. The bottom should not tilt down at all. Plug the unit in, and turn ON the Master ON/OFF Switch. Lower the humidity extraction level to 32 -35%. If you don't have an LED screen on your control panel, set the manual control to Maximum.
One other thing that you want to do on a regular basis. That's remove and clean the air intake filter, if necessary. Be sure to turn the unit OFF and unplug it, before removing the filter.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Goldstar DH304 Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Water leaks from the bottom front under the bucket. Bucket does NOT leak. Attached a piece of tubing from the outlet to the bucket to no avail. still leaks. No visibe cracks anywhere.
Try cleaning the filter first. Wash it with water and let it dry overnight. Then make sure no debris is blocking the inside of the spiggot which fills the pan. The spiggot can get blocked by dust anddebris or insect webs. Clean thoroughly with a rag and your finger.
Oct 07, 2009 | Haier AHD50 Dehumidifier
Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
Oct 06, 2009 | LG LHD45EL Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Unit overflows the condensate container with water.
To find out if it is the switch, unplug the unit and disconnect one or both of the wire to the switch.Plug back in and see if it quits filling.
If so it is most likely the switch is bad.
Jun 12, 2008 | Maytag M3DH30B2A Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
90 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
