Question about Video Cameras
Will not record or taje pictures. it says that memory is full even though i haven't used camera before. it is brand new!
  • 977 Answers
Hey!
This is a wild guess, but I think your SD memory card is locked...
Take it out and look at it's left side. There should be a small switch. Move it UP and it should all work now!
Good luck,
Pelu.
Posted on Aug 23, 2010
My camera always says internal memory is full even though there is a brand new memory card is inside
Did you format the card in the camera?
Also make sure you have the correct type of memory card.
For that see the manual.
Feb 27, 2014 | Cameras
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
The memory card in my pentax optio 60 is full. Can I record over it and if so how The memory card in my pentax optio 60 is full can i recoed over the top of it and if so how David
Certainly. If you're sure you've copied all the pictures you want to your computer, simply format the card to wipe it clean. Rotate the mode dial to the screwdriver-and-wrench position and turn the camera on. Use cursor-down to select "Format" and press the OK button. The instructions are in the "Formatting an SD Memory Card or Internal Memory" section of the manual (page 22 in my copy).
Memory cards should be formatted each time you finish transferring your pictures to your computer. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted regularly.
Apr 23, 2011 | Cameras
When i try to use my camera on my phone it says that my memory is full even though its empty.
To resolve this problem:-Turn off the camera and insert a new memory card.
-Transfer or delete pictures from the memory card.
-Change the storage location to use the internal memory.
Apr 21, 2011 | Cameras
Brand new camera, unable to take any pictures. Internal memory is full. Even when we put a mmory card in place, still thinks internal memory is full. Why doesn't the camera use the memory stick to save...
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Dec 28, 2010 | Kodak Cameras
I just bought a brand new scandisk 4gb card and it says that the memory is full even though i didn't take any pictures... what do i do?
The S700 uses SD cards. Your new 4GB card is actually an SDHC card. While it will fit into the slot, it will not work in the S700 (as you've discovered). You'll have to limit yourself to SD cards, 2GB and smaller.
Jun 22, 2010 | Samsung Digimax S700 Digital Camera
How do i empty my memory coming up memory full even though only 6 pictures on
the camera is meant to be used with a SD memory card - the internal memory is very small and probably will only hold 5-10 pictures. empty it just by deleting the pictures. memory cards are cheap and available everywhere. good luck!
Jun 20, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Apr 12, 2010 | DXG Technology DXG-409 Digital Camera
I recently purched a few diffrent memory cards and my camera keeps saying memory card full even though its brand new
You likely need to format the card before you can use it in the camera. Check your camera's manual for the format procedure.
Jul 14, 2009 | Kodak EasyShare CD33 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Video Cameras Logo
21 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
