Question about Whirlpool Duet GHW9150P Front Load Washer
What can I do to keep mold out around the front rubber piece in my washer?
Try leaving the door open when not in use, just enough to let air in. If its a big problem and its because its not being used much then leave a open box of baking soda inside, while not using it. Don't forget to take it out when your going to use it again.
Posted on Aug 23, 2010
Major mold around the rubber "drum"...tried everything to remove it but nothing has worked. How easy would it be to replace it? Help please!!!
You would need to pull it out of the track that is around the door panel itself and replace it with the new gasket. You may have up to 4 screws or clamps to help keep something like this in place. Make sure to keep the door cracked to help let water evaporate and not grow mold. Also, as in most Owner's Manuals, you are to clean it with bleach or vinegar to help prevent mold. Once mold grows, you can kill the bacteria from spreading, but mold stains and will always look like it is dirty.
Sep 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
Mold build up around rubber in washer drum. Can
Buy affresh washer cleaner. You can order it over the internet and this should take the mold off and then if you use this regularly like the package explains it will keep the washer from molding. I use this stuff on all the front loaders that come into my shop. This stuff works great.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold on rubber around door
Yes he can change it himself just make a note of how it comes off and then reverse the process when refitting, the black is caued by damp and residue detergent, try doing a very hoy wash occasionally this will prevent this happening, it should also cure the stale smell that you get from the machine.
Sep 01, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
