Question about Sony VAIO VGN-A790 Notebook
My Vaio VGN-A790 runs really hot. Now it's also running really slow. I ran a utility called SpeedFan. It says the effective clock rate is 688 Mhz s/b 2Ghz. I'm thinking the processor fried. I first noticed video performance issues but that could be attributed to the clock rate too, right.
  • LonThomas Aug 24, 2010
    I disassembled the unit yesterday and blue out the dust. I checked the fan and it turns. Seems like it's not turning very fast. Not really loud enough to hear. the cooling looked a bit on the cheesy side to me.
    For several years, I've had the laptop docked and KVMd with another PC. The high temp isn't so noticeable. I just noticed that loading a website takes forever, and videos? no way. the graphics soon start freezing or are really jerky while the audio plays on.
    Can I get a replacement video chip (I guess that's what's heat sinked next to the processor.
    appreciate the advice
  • 4,889 Answers
The overheating problem is the primary source of all the complications you are seeing. The reduced clock speed may mean that the processor is already hit. However I suggest that you open the back cover of the laptop and clean the heatsink(A copper wire that goes from processor to infront of the coolant fan. Make sure that nothing is preventing the airflow from the fan to heatsink. This page might help you with the dis-assembly
http://laptoprepair.ca/news/10822.html
Posted on Aug 24, 2010
  • Sony Master
  • 11,800 Answers
No, the speed is normal, since the data speed (2GHz) is equal to the effective clock (688MHz) multiplied by the data rate (4).
The video problems are caused by the heat - memory corruption. Check the cooler and the fan of the processor for dust (clean the inside fully) and make sure in Task Manager that no process is eating power unnecessary, slowing the pc down.
Posted on Aug 23, 2010
  • Azrael SRL Aug 24, 2010
    If the temperature and the image on the display itself are ok then the problem is software, not hardware - something is eating processor power and messes the settings.
    My guess is that your system is suffering from software rot - the most efficient way to fix that is to reinstall.
I have 688 hunter killer running on Windows 7. It only opens in window mode and the sound effects do not play. Music plays fine. I have already set to run in windows xp compatibility mode and run as...
For the sound effects to work you'll need to download SC (Starcraft) Sound Edit Utility.
Open up the utility and then open up file Sfx.agg found on a standard installation here C:\Program Files\Sonalysts Combat Simulations\688I Hunter_Killer\Sfx
Select all the sound files and extract them and you are done. If curious for me the sound files ended up in the compatibility files.
May 02, 2011 | EA - Electronic Arts 688: Hunter/Killer...
I have bought a sony vgn-n38e anf i am not able to scroll up or down on the right hand side of the touch pad, i would like to know if there is simply a button to press to rectify this or if it is possibly...
So you need to update driver for this touchpad scrolling error.
Please click on the below link
ftp://download.sony.com/US/pc/ALDOTH-00199336-US.EXE
This will download the driver for your touch pad then you need to run the driver that you downloaded.
Then restart the notebook
Check whether it is working.
you can find other drivers for Sony Vaio VGN-A790 on the below link.
http://www.notebook-driver.com/sony-vaio/sony-vaio-vgn-a790-notebook-windows-xp-drivers/
Hope this resolve your query.
Kindly provide your valuable feedback for this answer
Thanks.
Nov 11, 2010 | Sony VAIO VGN-A790 Notebook
How to install memory VGN-FS630/w
Computer is shipped with 512MB, PC-2700, 333MHz DDR (256MB x 2) RAM and Expandable up to 1GB max.
You can refer the page # 145 in the VAIO User Guide to install the RAM in the Computer.
http://www.docs.sony.com/release/VGNFS600-A790.pdf
Apr 15, 2010 | Sony VAIO VGN-FS630/W Notebook
Its seems that my Vaio VGN-FJ170 is been draging RAM. really slow
1-Try installing graphic-cards driver from the vendors home site!
2-Install a Codec pack like k-lite
3-use VLC-player
4-If yor graphics use shared memory , it could be a result of memory module failure.
Best of luck
Jan 05, 2010 | Sony VAIO VGN-FJ170/B Notebook
Cpu speed
ya u can update it through vaio update option in your laptop...
Mar 28, 2009 | Sony VAIO VGN-FS742/W Notebook
I can't find the second memery slot on sony vaio vgn a790
Second memory slot is under the keyboard. If you use link below and select 'user guide', then go to page 148 and it gives you detailed instructions on how to access the second memory.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNA790
I would appreciate feedback if this is useful. Thanks
Jan 28, 2009 | Sony VAIO VGN-A790 Notebook
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
Sony TZ240n problem.
If less than 90 days, it is under Sony's full coverage. Usually the fan runs intermitantly. Check that air paths are not restricted.
Aug 01, 2008 | Sony CPU FAN CPU Fan
Sony VAIO VGN-A790 Notebook Logo
81 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
