Question about Princeton Digital VL1916 19" LCD Monitor
Monitor stuck in "power saving mode"
Monitor is Princeton 19 inch LCD. It will only show a brief notice of "power saving mode then goes blank" If the cable is disconnected from the computer it will show a steady "no signal" box.
Help. I obviously cant do anything within the computer as there is no display,
  • Anonymous Sep 29, 2008
    I have the same problem, only with am LG Flatron. It was working perfectly until I unhooked it to move to another room and now will only show the Power Saving Mode" msg before turning black. I don't think it';s the computer since I went and bought a new one and it won't work with that either!
Just press the fn + F5 buttons and screen will appear
Posted on Dec 21, 2008
Testimonial: "solved, thanks"
  • 3 Answers
Using Microsoft Windows XP and others, Go to control panel and look for power options
Look through power options. Turn off Power saving items, You will see turn off after 1 Minute and so on.
last item indicates that you want to Never turn off Power Options. Set to NEVER then exit and reboot system. This may solve the problem Good Luck
Other option is to Go to Bios (Hold down Delete Key on Start-up) and look at power saving and monitor setings in Bios.
Good Luck
Posted on Nov 03, 2008
Try to test the computer with another monitor to make sure it's working ok.
Posted on May 05, 2008
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
My Princeton 19 inch LCD monitor keeps turning off and I have to un-plug it, wait, and plug it back into the wall socket for it to go back on. I replaced the multiple box and the power cord and am using...
bsims77010, Tell me brand name of electrolytic filter capacitors on the large "switch-mode-power-supply / CCFL inverter supply" printed circuit board. Are any of them SWOLLEN on the end that is up ??? You can see typical "failed units if you visit YOUTUBE for video clips that show owners/tech's that replace them with new ones and now have working units again. You must tell me more about this "keeps turning off" thing???? Is unit going to "black screen" only?? Or is it going to "black n blank" screen"??? There is a difference!!! If black only then 5vdc might be ok! If "black n blank then +12vdc & +5vdc sources could be in shut down mode. Do you see screen data with aid of bright flashlight held 1 inch from the "black" screen?? Once you have knowledge of what makes "raw white light" on reverse side of your lcd panel, then you will have clue to how the new screw-in, curlie-Q style CFL light bulbs work and what an "electronic ballast" circuit is. 12fixlouie
Post reply if you need further assistance.
Dec 14, 2010 | Princeton Digital VL1919 19" Monitor
I have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | Princeton Digital VL1916 19" LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Princeton Monitor
There is a field of capacitors on the power board that usually goes bad. I believe that there is a total of 6. When you look at the power board you should notice them. I have the capacitors if you need them. $2 each. Just check to confirm that they are swollen. and let me know the voltage and uF. good Luck. David
Jul 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
LCD monitor from "LCD Universe"
Inverter unit inside the screen may be defective
Apr 07, 2008 | Computers & Internet
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
647 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
