Question about Haier HD656E Dehumidifier
Bucket full light won't go off, even when bucket is empty....
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: even though I have emptied the bucket the bucket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Sep 09, 2010
  • 4736 Answers
SOURCE: Dehumidier works fine! However it
The drain hole of drain tube, that transports water to the bucket is clogged.
To solve this problem, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you solve the problem.
Posted on Jul 09, 2011
heatman101
  • 43501 Answers
SOURCE: bucket full light on continually,cannot
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
Posted on Aug 13, 2011
heatman101
  • 43501 Answers
SOURCE: Light for "bucket full ' stays on. None of
When the "bucket full" light is on then nothing will work...so...
Try reseating the bucket....
Check the float to make sure that the float or the containment around it has not filled with water...
Turn the bucket completely over and make sure that all water is out of the bucket...
Check the switch that the bucket pushes on when it gets full to make sure it is not stuck or broken...
If the switch is broken then it may need to be replaced...
Here is a tip that explains what can be happeningto make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Aug 29, 2011
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The "bucket full" light blinks even after the
Eddie, turn the unit OFF & unplug it. Then remove the bucket and check the float valve in the top of the bucket. It may be stuck in the 'UP' position or is broken. When reinstalling the the bucket, be sure that it fit's "squarely" from top to bottom in the bucket holder and is making firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | LG LHD65EBL Dehumidifier
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
Full light won't go out and it won't run
Hi and welcome to FixYa, I am Kelly
Most likely the sensor assy has failed. See section 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520042&diagram_id=28700153#d28700153
Detailed View: ($18.04)
http://www.appliancepartspros.com/part_details.aspx?part_id=4652359
This senses water and humidity levels.
Thanks for choosing FixYa,
Kelly
May 28, 2011 | LG LD65EL Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
Even though I have emptied the bucket the bucket full light will not turn off and the dehumidifier will not reset. I tried unplugging the unit but when I plug it back in it still says bucket full
heatman101
Aug 29, 2010 | Haier 45-Pint Dehumidifier
Haier HD656E Dehumidifier Logo
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
