SOURCE: acer aspire 5517 touchpad doesn't work. We have
On my Acer Aspire 5534, up above the keys there are 2 buttons that are side by side. one is to turn the wireless off and on and the other one is to turn the mouse pad off and on.
SOURCE: I DON'T KNOW HOW TO TURN ON THE WIRELESS
[1] make sure the switch for you wireless network is turned on, and I think it is either located between the screen joints and the keyboard, or right on the side of the computer [the side that always faces you when the computer is on the laps]. Next, check to see if it has detected any wireless Networks, you could do this by right clicking the icon for the wireless network, in your bottom right corner and clicking on 'view available wireless networks'. if they do not show, you will have to refresh. When the links are listed, select the one you wish yo connect to and click 'connect'. if it needs authentication, you'll have to provide a network key
SOURCE: how to turn wireless capability
is your Wireless driver installed if no Make sure u installed and turn your Wireless On
SOURCE: 'turn on wireless capability' Acer Aspire 2930
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE..
SOURCE: My wireless capability switch is turned off on my
wireless capability on my acer laptop is a switch that you toggle on the front of the computer.
I suspect that you just need to slide the switch over and release to turn the light on for WiFi and also to turn the WiFi capability on.
If you click Start > Settings > Network Connections
Is there a wireless network adapter here
