Question about GE WSXH208A Front Load Washer
Cant figure out how to unlock control lock...can't find manual...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the OPTIONS & SELECT button together for 15-20 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 24, 2010
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 16, 2010 | Whirlpool Washing Machines
How to unlock a picture
Go to the playback menu and select it (you may have to adjust the circular option know to get to the playback menu). Once there, scroll to the picture(s) that are locked by using the sideways selection arrow buttons. Then select the up or down arrows, which will lock or unlock your picture. You can also erase any locked pictures, in case you want to, by formatting the xD card. Hope this helps.
Mar 25, 2010 | Olympus FE-210 Digital Camera
Cant unlock child lock on dvd player
Some require you to put in a code so your kids don't fu.k with it and turn it off.  Check your manual.
Oct 30, 2009 | Philips Universal PH301S Remote Control
Keyboard lock
i think settin of yor computers key board is change. go control panel and click on key board then look setting and correct it, thanks
Jun 20, 2009 | HP Pavilion ZV6000 Laptop
Cant get Audio Controls to unlock!
Put it in standby mode by pushing source. Then go to the menu and hit system setup. Select page 3 I thing and turn output from rear to sub. Now you should have control from the audio menu.
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
Hp pavilion laptop
MY COMPUTER GOT LOCKED I CANT FIGURE OUT HOW TO UNLOCK IT. COULD YOU PLEASE HELP.
Dec 26, 2008 | Computers & Internet
PROGRAMING ALARM REMOTE ON 95 TAHOE
Here it is straight from Alldata:
  1. Ground pin G of the Data Link Connector (DLC).**Bottom left pin**
    • Receiver will respond by locking, and unlocking doors within 2 seconds.
  1. Press any button of the first transmitter to be programmed.
  2. The control module will respond by locking/unlocking doors and activating rear window release.
  3. Press any button of the second transmitter to be programmed (if used).
  4. The control module will respond by locking/unlocking doors and activating the rear window release.
    1. Remove the ground applied to the reprogrammed connector.
      1. Transmitter operation is verified locking and unlocking the doors and activating the rear window release
Dec 23, 2008 | 2007 Chevrolet Malibu SS Sedan New Cars
Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
Jul 27, 2007 | GE Advantium 120 Convection/Microwave Oven
GE WSXH208A Front Load Washer Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
