Question about Kenmore Elite 45986 Front Load Washer
I get two codes , dL and F. I cleaned the filter but stil get both codes. Thanks
  • 5,911 Answers
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot this problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
For a full explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Posted on Aug 23, 2010
Where is the "pot filter" on a Whirlpool Duet Front Load Washer Model GHW9400PL0 and how do i properly clean it?
its probably behind the kick strip at the bottom of the machine. Might be a little screw to remove
Jun 16, 2014 | Whirlpool Washing Machines
Hyundai atos 1l power loss, jerks
If your mechanic did clean your gas tank he probably reused the tank sock which is sort of a prefilter and should be left off after cleaning, you have an inline filter and that is enough unless you get some really trashy fuel that would clog the sock and the filter and without the sock all you would need to do is drain the tank and replace your filter.
Mar 18, 2014 | Cars & Trucks
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
My 2001 grad prix stumbels at acceleration once in awhile and in park sometimes there is no engine codes and i've changed pretty much everything plugs wires coils fuel filter and i even cleaned th
You did oxygen sensors at 100,000 miles
No exhaust leaks
No intake or evap leaks
Changing parts doesn't answer the question
Do you have ignition misfires
Egr problems
Mar 13, 2013 | 2000 Pontiac Grand Prix
WHEN THEY CAME OUT TO SWITCH OUT THE BOARD FOR THE F1 CODE THE GENTLEMAN TOLD ME IT WAS OK. I HAD TOLD HIM THAT DL CODE WAS COMING ON AS WELL AND ALL HE SAID HE WAS ONLY SUPPOSE TO CHANGE OUT THE BOARD....
2 things- 'DL' and 'smells!
'DL' stands for 'Door Lock (Error)' indicating that there is a problem either with the door lock or the door locked sensor requiring another service call, sorry ;-0(
I CONSIDER IT DISGUSTING THAT THE SO CALLED GENTLEMAN WOULD NOT ATTEND TO THE 'DL' AT THE SAME TIME. THAT MEANS IT WILL COST YOU A DOUBLE VISIT.
Smells
Bad odours could be coming from a few places.
  1. the plumbing u-bend of the washer's room or
  2. the fact that there is 'foul' water being left in the drum.
  3. No washes at 90 degree+ !
I would suggest checking the plumbing u-bend for trouble first, then following the notes on checking and cleaning the drain filter and the drain pump to ensure there is nothing 'obnoxious' hanging around the two of them! Finally run the occasional 90+ wash, or use specialised lower temperature powder/fluid, to kill bacteria.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these have assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 17, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
2001 vw gti 2.0 non turbo oil idiot light flashes randomly over 2000 rpms...did oil change , filter , new oil sensor above to right of filter, and light still flashes
check oil straner inside oil pan clean the filter and check if stil. you should replace crank bearing. and con-rod bearing and (oil pump ) you can start by replacing con- rod first .
Jul 06, 2011 | 2001 Volkswagen Golf
Washer giving a code error DL and F
clean water pump filter of foreign objects,99xout of 100 that is the problem
Nov 27, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't start. falshing the letter F then the lower case letters dl.
DL means you have a draining problem.
Clean filter, drain and or pump
Jul 28, 2008 | Whirlpool Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
