Question about Sony Playstation 3 (PS3) Console
Playstation 3 power on issue
When I try to turn on my playstation it tries to start up and then it just shuts down. what could be causing this?
Thanks
Steve
  • H king May 05, 2008
    When i turn the game on it boots up and a yellow light in the front flickers on and off and in the middle of my game play the console shuts off. I've plugged the wires out and placed them back in and even stretched the wires and the game still turns off.
I have A Problem like that..
When i turn My ps3 on
It Shows a Blue screen
Then My Console doesnt Respond anymore.,.
So it says ( When the Screen Does Show ) That i have to format My Console
It starts to make strange sounds to when i Hit the power button On my ps3 ...
Ps3 Sucksss !!!
Posted on May 05, 2008
When i turn my ps3 it automatically starts to download the update, i cant do anything else unless it finishes, but it only get to 99% and stays there, it never finishes. i try to get the reboot menu by...
Your issue could be because the Playstation Network is actually down.
It was basically 'hacked' and Playstation shut it down. It should be back up by the 31st.
May 10, 2011 | Sony Playstation 3 (PS3) Console
Hi. My PS3 suddenly started turning off randomly in the middle of play (grrrrrrr) but I know its not overheating since the red light didn't flash and there was beeping. It just died. No joke. Does anyone...
There could be an issue with the power cord or the power outlet.
Try to get a replacement cord and plug the PS3 into another outlet. Turn on the PS3, and let it sit on the menu screen for a while. If it does not shut down it means that it was a power issue.
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
I was playing black ops. it froze loading the next game. i held down the power button until it peeped, then it shut down. now my controllers will not turn on or even communicate with the system. i try...
Hello Gdemon6 Here is a step by step instruction on how to fix this issue.
Firstly turn off your playstation 3 controller, insert the USB cable into the playstation and then the controller. Have a small pin to hand, when its flashing press the button located at the back of the controller to the top, next to the screw hole. It is a very small hole, go to settings in your playstation 3 menu. Under accessory settings, go to recalibrate controller.
Your playstation 3 controller should now be ready to use properly without any issue. Any further questions please feel free to ask. Thanks for using fix ya.
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
Game turns on then shuts down
Hello.
You may have a lot of dust in your fan causing the playstation 3 to overheat and emergency shut down before it fries the internals. Try taking some CO2 compressed air spray from your local store and blast the dust out and then try it again. Hope this helps!
Dec 01, 2009 | Sony Video Game Consoles & Games
I was playing online when the console shut down and the light on the front started blinking red. when i try to turn the console on the green light comes on and then turns yellow and then goes back to...
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Also be sure to rate whether this helped or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
If the PLAYSTATION 3 feels extremely hot or the system will power off and the power light will flash, this could be an indicator there is a temperature issue with the PLAYSTATION 3 and it is not able to keep the system cool. Please attempt the following troubleshooting steps.
  • If there is no airflow from any of the vents, the system may need to be sent in for service.
May 25, 2009 | Sony Playstation 3 (PS3) Console
Turning off when game is playing
May 25, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
168 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
