Question about HP PHOTOSMART PLUS B209A All-In-One Printer
We are using Verizon MiFI for our wireless router connection. We can print wirelessly from our new Dell laptop with Windows 7, but our older Dell Laptop with XP will not print consistently. We get the error that the printer is offline, however when we check it, it is not. The older laptop is being used at the same time as the newer one; both connected to the MiFi. What do we need to do to print on the XP laptop??
PABLOCSA
  • 1124 Answers
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Posted on Oct 03, 2008
  • 16 Answers
SOURCE: HP photosmart C5580 wireless printing problem
You laptop will not be able to connect to the printer using the bluetooth technology. But the good news is that you can use the printer thru your home network by having the desktop that the printer is connected to be part of the same home network that your laptop is part of and then share your printer on our desktop and then select it as a printer to use on your laptop.
This link has instructions for all of your home network instructions.
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Posted on Aug 05, 2009
  • 16 Answers
SOURCE: printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Posted on Aug 10, 2009
  • 685 Answers
SOURCE: My HP Photosmart C6380 keeps saying "offline" via
Give this a try...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02221706&cc=us&lc=en&dlc=en&product=3560280&tmp_track_link=ot_search
Posted on Sep 30, 2010
  • 17 Answers
SOURCE: I have a new HP
I assume you fellow the steps in the manual and install everything correctly. We had the same problem on our hp printer. Sometimes, if you install Windows/software updates, it will put your printer offline. The problem will disappear once I restart my computer.
Posted on Feb 28, 2011
My system is mifi jetpack 5510l with 10 gb with android tablet teame to use less data
Spend less time playing online chess outside your house where you have to connect the MiFi Jetpack to your laptop and use your data plan and more time playing at home over your home network where you do not have to use the jetpack and your data plan.
Jan 01, 2015 | Novatel MiFi 5510L Jetpack 4G LTE Mobile...
How to monitor router using Wireless Connection & Networx
Simply install a data usage app on your laptop. You can locate one in the Windows Store, Google Play or by doing an internet search One of these will monitor every incoming or outgoing byte of data with a custom report available of pinpointing data usage overall or to a specific day or hour.
Apr 01, 2014 | Novatel Wireless MiFi 4510L 4G Mobile...
My older computer with a dell 1450 usb wireless adapter cannot find my Verizon MIFI hotspot, it does see other wireless networks in the air
Most likely the adapter and the hotspot do not support the same wireless standards. Verify they both support a similar standard and they the hotspot is broadcasting in that standard.
Current standards are 802.11a,b,g,n
Nov 22, 2012 | Dell 1450 (D1450U) Wireless Adapter
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
I have a Dell desktop and a Dell Laptop Inspiron E1705 both run Windows XP Home. My internet connection is Comcast cable. The Desktop runs of the comcast modem and for the laptop I have a comcast router...
Dell laptop will have a dell wireless application that will be controlling the wireless adaptor.
You can open that from Start - Programs (or all programs) - Dell - Dell wireless utility (or in some case intel proset utility). open that and you can use it to connect to your wireless network or you can disable it and allow windows to manage the wireless adapter.
If you have any issues in doing the same please reply to this post.
Thank you for contacting Fixya.
Jan 20, 2011 | Dell Latitude D600 Notebook
How can I boost the signal of my Verizon MiFi 2200 in my home? Can I attach a Linksys router to the unit?
You cannot connect a router to your Mifi as it does not LAn port. You can use wireless access point to amplify your wireless signal
Sep 13, 2010 | Novatel MiFi 2200 Mobile WiFi Hotspot...
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
How do i connect MiFi2200 to a wrt54g?
I think this won't work...the MIFI device works as a wireless router that can supply 5 connections and runs on battery which last for 4 hours for one connection then goes down as more connections are in...the MIFI was designed for mobility as the WRT54G is not...I don't exactly know what your plans are but this won't work well.
The Verizon MiFi is a combination 3G modem and Wi-Fi router that is battery-operated for full mobility. Once the MiFi has been activated (more on that later) the device connects to the Verizon Mobile Broadband network (renamed from BroadbandAccess) simply by pushing the power button. In just a few seconds, the MiFi is connected to the 3G high-speed network and the Wi-Fi router takes over. The MiFi appears as a hotspot to any device with Wi-Fi capability, and making the Wi-Fi connection is as simple as entering the network security code which is printed on the back of the MiFi. That’s it: The notebook or other device is now connected to the Verizon network via Wi-Fi. The network code only has to be entered to make the first connection, after which it’s an automatic process. That’s the beauty of the MiFi method: Push the power button and the laptop/UMPC/phone is connected to 3G.
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
206 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
