Faulty dc power jack
I was wondering how much it would be approximately to replace my dc power jack. It keeps flickering from battery to ac adapter power, and only stays charging if I create a lot of tension on the ac adpater cord. I have a gateway mx6440.
Thanks
  • 197 Answers
Www.bixnet.com/gamxmxmxmx.html
here is a link that might help you the one i looked a was about 60.00
Posted on May 04, 2008
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
R519 move ac power cable light flicker on/off
This could be an AC adapter problem.Use another same rating adapter for teating.Check your ac adater volt and ampere at output terminals using a good quality digital multimeter. If OK, check the battery also. Then only suspect motherboard and power jack. Hope this helps
Dec 05, 2012 | Samsung R519-53S Notebook
The battery cannot charge after connecting to a power source
Take out of your battery, then plug in your ac adapter, see if it works, if no, then you have a faulty ac adapter, you need to replace it; and if yes, then you adapter is ok, the battery or dc jack may be broken.
Jun 01, 2011 | Lenovo IdeaPad Y450 20020 Laptop AC Power...
I have a toughbook cf-19 and the charging lite keeps blinking red
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 29, 2011 | Panasonic Computers & Internet
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
My Toshiba Satellite AS205-5000, will not turn on nor does the fan come on. When the low battery sign came on, I plugged in the AC adapter to charge it, and it shut down and wasn't charging. After it shut...
You Need To Replace the DC Jack..this involves desoldering the old/faulty dc jack from the motherboard, then cleaning the board, then soldering a new dc jack in place of the old...
But First, Test Your AC Adapter - use a multimeter (available at any home improvement store for under $7)...
Nov 14, 2009 | Toshiba Satellite A60 Notebook
When you plug in the ac the power is intermittent and then will go into hibernation. With a full charge the battery will last about 30 min. If you unplug the battery the ac will work for a short time then...
Sounds like you have a loose DC jack or a faulty AC adapter. Try testing the adapter with a multimeter (or have a someone do it for you) to see if it's output is consistent. If you wiggle the ac adapter plug slightly when it is plugged into the jack on the notebook and this causes the power to go on-and-off (you should be able to tell by a power/charge led on the notebook) it is likely the DC jack if the AC adapter tests ok.
Prices to replace the jack vary. My shop does it for $65 labor + $15 for the jack on most non-apple notebooks.
Sep 21, 2009 | HP 510 Notebook
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
