Question about Mitsubishi WS-65807 65" Rear Projection Television
No inputs were accidently selected. How do I do a factory reset if I cannot get to the on-screen menu? I was turning off inputs (tired of going through the list when all I have connected is a dvd player and I turned all the inputs off. Now, I cannot get to the on-screen menu system to turn on an input. How do I reset the TV to factory default (hopefully, all inputs "on"?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Confirm actual model number and that you have a working Mitsubishi remote. I can tell you how to reach the option menu where you can do a hard reset--NOTE, IF YOU CANNOT SEE THE NORMAL MENU ON SCREEN THE HARD RESET WILL NOT BE POSSIBLE.
iF YOU WANT TO TRY ANYWAY rate this solution as very helpful and I will give you the code for the Option menu.
SD TECH
Posted on Aug 23, 2010
How do I do a factory restore on a Coolpad 3300A
http://www.hard-reset.com/coolpad-quattro-4g-hard-reset.html
Coolpad Quattro Hard Reset (Factory Reset)
    1.Turn off your Coolpad Quattro phone and pull out battery and reinsert it after a few seconds
    2.Press and hold both Volume DOWN + UP and hit POWER button until "Recovery mode..." showing on the screen. When the triangle with an exclamation mark appears touch the HOME touch key to enter Recovery menu.
    3.Select Factory reset/ wipe data. (scroll down with VOL down.)
    4.Select with power.
    5.Scroll down to Yes - delete all user data. Press power to confirm. If your phone is responding to screen input, then open Settings from the Applications menu. Tap Backup & reset > Factory data reset; click Reset phone and Erase everything to format your phone.
Jan 04, 2016 | Computers & Internet
None of my inputs work on the TV, including the Ethernet connection
test with your cell phone directly then reconnect the modem last reset tv to do so in main menu
Sep 15, 2015 | Sony BRAVIA KDL-55EX710 55" LED TV...
Forgot mypattern to unlock phone its a concord zte768 I think can u help me
Try these steps:
ZTE Origin hard reset Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off.
2. Hold down Volume up key and press Power key at same time until the screen lights up.
3. Press Home Key to access Android System Recovery screen.
4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu.
5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset. ZTE Origin V768 Phone Password A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Jun 05, 2014 | Cell Phones
Zte n910 is locked need to hard reset for zte n910
Warning Hard Reset will erase everything on your Device !
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
Apr 16, 2014 | Clear Screen Protector - ZTE Anthem 4G...
Lg 42ls575t won't go to "input" screen or "home" screen so cannot select HDMI channel. "Loading" message appears for 30s or so then disappears
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
Apr 15, 2013 | Televison & Video
None of the video inputs are working but the audio is fine.
Hello
You just make all vidieo input options to factory setting and try.
To get it follow this.
Press the MENU button.
The main menu appears
Surf through and select the Video Menu
To select the Vodeo Menu DISPLAY==>HILIGHT==>SEELCT
To restore factory settings :- Press reset on the remote control while the Vido Menu is selected. To restore each Mode to factory settings press reset after selecting the mode to be reset.
OK
Dec 09, 2010 | Sony KP-48V90 TV
Low tire pressure light wont go out
The Low Tire Pressure Indicator must be reset using the Radio. This can only be performed if you have the factory radio installed in the vehicle. This vehicle does not come with an active tire pressure management system, and as such, this light must be reset manually.
1.) Turn Radio Off 2.) Hold down disp button for 10 seconds 3.) Setup Menu should display 4.) Scroll through menu to view "Tire Pressure" (use seek buttons) 5.) Select the Tire Pressure option (Press Radio Button 1) 6.) Reset should be displayed on screen (Press disp button) 7.) Tire Pressure Light should reset
Nov 29, 2010 | 2000 Chevrolet Impala
My cable input has disappeared. All I have are HDMI, AV, and PC inputs. And the entire selection in the menu for channels is gone including auto channel scan.
- Press Menu
- Press 991
- Go down to Memory recall and press enter
- It will ask you "ARE YOU SURE"?
- Select "Yes" and press enter
- It will take you back the menu screen, turn off the TV and turn it back on user_offline.gif quote.gif
May 18, 2010 | AOC L22W898 22 in. LCD TV
I accidently selected in the setup for TV type> Aspect 4:3 & 480p. The setting was on Aspect 4:3$ 480i. Now I cannot stop my screen from rolling so I cannot get back into the Setup area to change it back....
connect an rca connection cable on the yellow video output on your dvd player to your tv, grab your tv remote and select that input, then go to the setup menu on your dvd player and change the settings.
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have no 'input selection' on my Sharp HDTV 37", model LC37DW99U
On your menu, go to the channel settings. Go to add/delete channel. You will have to add this channel manualy. The tv might have went into autoprogram mode and deleted it.
Feb 02, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
