Question about Dell Latitude D600 Notebook
Desktop disappears after booting
After has finished booting and desktop has loaded, after only a few seconds the desktop disappears and screen is blue. The cursur will still move but nothing is present on the desktop
    Genius:
  • 3,587 Answers
Sounds like a blown operating system. got a recovery disk handy?
Posted on May 04, 2008
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
How to skip logo and long boot sequence
That is booting directly into XP. The Windows XP logo that you stare at for a few minutes is actually hiding a whole lot of back end system checks. Without the logo you would be looking at a blank screen. There is a difference in load time, but it's about 2 seconds.
May 17, 2012 | Acer Aspire M1641-U1521A PC Desktop
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Windows Vista shortcuts disappear!!
Basically a friend showed the power 4 extreme option by right clicking on the battery icon at the bottem right of the screen and then setting in the quiet office section to say no to hide desktop icons. Now its no longer a problem!
Sep 01, 2009 | Microsoft Windows Vista Home Premium with...
Sony PCV-A11 desktop won't boot up to windows. I see the Sony sign and pentium 4. Computer goes to a black screen with a blinking cursor. If I try to type something it won't accept. This all occured after...
Use your installation CD for Windows that came with your computer, and boot to the CD. (Usually, pressing the F12 key will offer your boot options such as "Boot to CD.")
Once booted on to the CD, it will offer you several options - Do NOT reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"chkdsk c: /r"
It will take a while for it to work all its magic, but that should fix your problem!
When it is finished, you can simply push the power button on your computer to turn it off.
When you next turn it on, it should be happier.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
Wont go past loading screen
shut it off let it sit for like 10 mins then plug everything back in then try it
Apr 20, 2009 | HP Pavilion a1330n (EL466AA) PC Desktop
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
G4 problem
Hi, Try shutting the G4 completely down, waiting about 15 seconds, and then booting the Mac with the shift key down. That should clean up a lot, as it gives a safe boot. Then go to disc utilities and repair permissions. That might clean the whole thing up for you. If sounds like it's a Finder problem. If that doesn't work, boot from Disc Warrior or Tech Tools and run a few tests. Good luck!
May 09, 2008 | Apple iMac G4 Desktop
No display
I believe you are referring to a desktop PC.
You can press F8 repeatedly while booting to get the Boot options screen. It should contain a VGA Mode - this will boot your regular desktop with a lower resolution. Once in windows adjust the screen resolution to one that your Monitor supports.
Right click the desktop anywhere. Choose properties. Go to the right most tab "settings". Slide the screen resolution option until its where you want it. Click Apply. Do Not Hit any keys on the keyboard. Wait until it finishes changing resolution than click Ok. Close the Window.
If your screen goes black during this waiting 30 seconds should automatically revert it to the previous settings.
May 07, 2008 | Dell Inspiron 8500 Notebook
Dell Latitude D600 Notebook Logo
69 people viewed this question
Alun Cox
