Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pink Hue My SD-533HD5 has a pink hue for about the 1st hour, then goes normal, but today I have a blue and yellow warped color at the bottom. What could this be?
  • Robinbird802 May 07, 2008
    We have all different models of projectors showing with either pink or yellow hues.
    Tried changing the computers, laptops, projector settings -- no change still pink or yellow.
For me it was a setting on the laptop -- call the proj manufactor and ask for their online pdf manual....
Posted on Oct 13, 2008
    Scholar:
  • 136 Answers
It must be the problem of convergence in the tv.
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Top screen of DS has pink hue.
this is happening to me right now and i just say call nintendo dog
Oct 25, 2008 | Nintendo DS Console
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
129 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
