I have a wilson safe,model 13850. I have the combination, but I'm having a hard time using the turn dial. Is it left,right and left and the combo is three,two,one?
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Posted on Jul 09, 2008
SOURCE: sentry 3100 safe_i remember combination but do not remember which way to turn
go around 3 times to the left
stop at the 1st number
go to the left one full time and pass the # but stop at the 2nd #
go to the right and stop at the 3rd # the 1st time you come to it
I just bought one last night
Posted on Sep 13, 2008
  • 77 Answers
SOURCE: How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
Posted on Feb 18, 2009
johncaman
  • 201 Answers
SOURCE: Have a Sentry S0409, haven't opened in a long
Try this document - there is a section on dial combonations, lots of turning involved....
Posted on Mar 04, 2009
SOURCE: Problem with SAGI oven
Problem with SAGI oven Problem with the Kitchen Rangesrange.jpg I have a probelm with my Sagi Oven [not sure what model] I am bought my home and it came with this oven and there is no manual provided. There are three dials. A temperature dial, a dial to select the options of light, grill, oven [represented by pictures of lines] and a third dial which has a timer and a picture of a hand. If I bake on fan the food is getin very dry and is very slow( to bake chops take me 2.5 hours covered with foil). Any suggestions would be appreciated. Thanks! - By VIKI
Posted on Jul 17, 2010
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Dec 01, 2010 | Safe International SentrySafe Home/Office...
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Insert your sentry safe key and turn it until the plunger pops out.
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Have Sentry 1250 safe. I have the combo but can't get it to work.
A1 locksmith will tell you.
Pull the handle down; cracking sentry safe open.
Jan 29, 2009 | Sentry Fireproof Safe
Brinks safe
As I understand that safe has four numbers to the combo. 1) turn the dial to the right passing the first number 4 times stopping at that number the next time around. 2) Turn the dial to the left passing the second number 2 times and stopping on that number the next time around. 3)turn the dial to the right passing the third number 1 time and stop on that number the next time around. 4) Turn the dial to the left stopping on the last number. 5) Insert the key into the cylindrical lock and turn it to the right.
Sep 03, 2008 | Check Point Network Adapter
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
245 people viewed this question
jasbo
jasbo
