Question about Amana Refrigerators
Model #36795 - cool alarm keeps going off have to set to max cool
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 23, 2010
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
What exactly does max a/c and norm a/c do; the difference, and performance? What does recirc do and why is it available during max, norm, and bilev but not during defrost? The same a/c properties are...
Hello: Max cooling is when the recirculate door opens. With the recirculate door open, 80% of the air flow comes from inside of the car and 20% is outside air. That makes the cooling more efficient. Normal a/c operation is 100% of airflow comes from the outside. These settings have nothing to do with compressor operation. Also Decreasing or increasing the amount of cooling has nothing to do with compressor operation, what that does is control the amount of air going from the evaporator core either through or past the heater core. The a/c compressor runs the same amount of time regardless of settings on the control panel. Also in cool weather the compressor runs in the defrost mode to keep the windows from fogging up. None of these settings affect performance, the only time performance is affected is wide open throttle (WOT) in that mode the engine computer shuts off the compressor to allow max power of the engine, ie: passing gear.. When A/C is selected the compressor is on, none of the settings will affect gas mileage, ie, low/high, max/normal 60 degree or 90 degree.
Jul 22, 2011 | 1997 Buick LeSabre
Fridge motor, I think, is making death rattle noises and the alarm keeps going off every few days
ck the cond fan as this is a very common problem . if its going to slow cooling will be poor and alarm will keep going off . / also dirty cond coils will cause poor cooling but not the noise .. mm
Jul 03, 2010 | Fisher and Paykel E522BLX Bottom Freezer...
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Alarm
master reset the phone then set it again
May 02, 2008 | Motorola Mobility RAZR V3
Refrigerators Logo
76 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
