Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
My refrigerator is making a clicking noise coming from the control board relay. fridge has been cooling fine but im guessing that relay will eventually fail. When I completley turn up the temp on the freezer tstat the ticking goes away. What is this
  • 1 more comment
  • thetravical Aug 23, 2010
    My refrigerator is making a repetitive clicking noise which I'm 95% clear is a relay on control board not closing properly. When I turn up freezer side tsat this stops.
    Why is this happening, or how can I eliminate possibilities. I'm not an idiot....please don't send me the manuals answers from the trouble shooting section but real service advice. Thankyou
    why does lower temps effect operation of relay
    Brigadier General:
  • 5,158 Answers
Because the clicking sound is the relay completing a connection and i presume shutting off the connection at certain temperatures. setting it on maximum tends to cause the relay to stay engaged all the time. i wouldn't be too concerned about it clicking. if you ever hear the relay(s) making a chattering sound they are likely failing.
Posted on Aug 24, 2010
  • 10,319 Answers
The relay will not hold at lower temps so better replace that board soon
Posted on Aug 23, 2010
    Genius:
  • 1,622 Answers
A noisy chest freezer can be more than aggravating, it can also be a sign that something may be wrong with the appliance. With a little investigation, you will be able to find the cause for the noise so that you can determine how to rectify it.
Self-defrosting
If you chest freezer is a self-defrosting variety, you will find that it has a fan on one of the inside walls that enables this process to take place. Open the door and check whether this makes the sound worse; if this is the case, the problem is likely to lie with the fan. Ensure that it is not blocked by any food items or ice and is running properly. Clear away any items that are blocking it and tighten any loose fasteners. The motor that runs the fan can also cause a noise if it is old or defective and is struggling to continue running, if this is the case, the motor will need to be replaced.
Door Seal
Examine the door seal of the chest freezer to ensure that it is intact and has no defects. If there is a problem with the seal, it can prevent the door from closing properly which will force the freezer to work harder as it will also be cooling the air around the freezer. Replace the door seal and ensure that the door is able to close properly to see if this reduces the noise.
Element
The wire element that is either located on the rear or the base of your chest freezer. The element can often become noisy after getting covered in dust and debris. Rectify this by switching off the power supply before vacuuming the element. Carefully use a cloth to clean any other surrounding components that are affected by stubborn grime.
Ice Build Up
Where your chest freezer is unable to regulate itself, you may find that it can suffer a buildup of ice. When the ice become sufficiently thick, it will stop the freezer from being effective and will force the motor to work harder in order for it to keep working. Prevent this problem by defrosting your freezer on a regular basis or whenever it is required.
Condenser Fan
The condenser fan is likely to be located at the rear of the freezer and can become noisy if it is defective or covered in dirt. After switching off the power supply, use a cloth to clean the blades of the condenser fan if you find that the noise is coming from this component.
Compressor
The compressor is the black box that you will find on the base or rear of your freezer and is where the normal noise of the running the freezer comes from. The pipes and wires necessary for the freezer to work stem from this box and can become noisy if there is a problem, which is more likely with an older appliance. A defective compressor cannot be repaired so it will need to be replaced.
Thanks for using fixya....
THE rEFRIGERATOR IS NOT COOLING OR FREEZING AND IT MAKES NOISE WITH THE RELAYS WHERE THEY ARE CLICKING ON AND OFF. dO NOT HEAR A FAN BLOWING OR THE UNIT MAKING COOL AIR.
I did not see a model or brand on your request but i'm going to guess that ist a G E and the clicking rellays are a common noise when the program board has failed . the unit will shut down / as the board controls the compresor and fans / heater //defrost cycles . if more help is needed i need the brand and model # .. hope this helped mm feed back pls and thanks for ysing fix ya .
Dec 11, 2010 | Refrigerators
Refrigerator is not cooling like it should. There is a constant clicking noise coming from the freezer side. When I open the freezer I can see that the fan is not spinning. The Model # is GSS251FRFBB.
You have a defective relay in the control board on the rear of the refrigerator. The control board must be replaced.
You can do it yourself and save money.
Pull the fridge out. The control board is behind the metal cover on the back. Remove the 6-8 screws to get the board cover off.
Unplug the refrigerator to remove and replace the board.
Dec 25, 2009 | GE Refrigerators
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
My GE Refrigerator makes a terribly high pitched whistling noise when it is running. Any ideas? It works fine.
If you can track down exactly where the noise is coming from I would guess it's coming from the control board. Some are located on the back about middle ways up on the right side. Some are located in the control area inside the fridge. A model number would help with locating it.
Oct 29, 2009 | Refrigerators
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge not working.
not sure if that model has it but if it does have a control board it will be on the back of the you will see a panel with several screws in it the relay on it is stuck need to change the control board But if it dont have a control board on it then change your relay on your compressor if you need anything else let me know and please rate me
Jan 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Hotpoint refrigerator hss25gfpj ww, clicking constantly, not cooling!!!
Recently had a friend with the same problem. Found that one of the power supplies on the board had a blown capacitor. This allowed the relay on the board to energize but not enough voltage was being sent to hole the relay closed. Basically a blown board was the problem. I found the wiring diagram very informative, it was hidden behind the temprature potentiometers.
Oct 21, 2007 | Samsung RB1955 Bottom Freezer Refrigerator
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
138 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
