Question about Directv RC32RFK Remote Control
Weird battery size
I recently got a message on my TV saying that my batteries are low and I should replace them.
I took the batteries out and tried to replace them with some other AA batteries I had, only to find that the batteries that the remote came with (http://www.consumer.philips.com/consumer/en/us/consumer/cc/_productid_R6LS2A_27_US_CONSUMER/Battery+R6LS2A-27) are a different size than "normal" AA batteries.
I took the weird-sized batteries to Target, but they didn't have any AA's except standard sized ones.
Where do you all get your batteries from? Should I just jam some regular AA's in there? They'd fit (I think) but it's be extremely tight and I'm worried that I won't be able to get them out when they die and then I'll have to buy a new remote.
This is really frustrating. I don't know why they couldn't manufacture their remotes to use normal AA batteries.
Use the AA batteries thats what i use and it still comes in and out
Posted on May 07, 2008
2 Suggested Answers
SOURCE: weird battery size
Here's a link on the Directv forums. They suggest putting a small ball of aluminum foil between the positive terminal on the battery and the contact on the remote.
http://forums.directv.com/pe/action/forums/displaysinglethread?rootPostID=10316895
Posted on Jun 07, 2008
What is the RF error message? And after I changed the batteries, the system still says low battery. Help. Thanks,
Is it saying "System Low Battery"? There is a NiMH battery pack inside that needs to be replaced roughly every 5 years. There a 2 clips at the top that have to be pushed in to release the cover, which is hinged at the bottom...you'll find the battery pack inside. You'll either have to try to get a replacement from the manufacturer, your alarm company (if you have one) or take the pack to a battery store and have them make one for you. Hope this helps...
Jan 07, 2015 | Honeywell | Ademco LYNX Plus LYNX Plus
MESSAGE ON THERMOSTAT SAYS BATTERY LOW
The cover on your thermostat should snap off pretty easily by pulling gently on lower right corner.Remember to not force it,if it does not open you can try one of the other corners. Under the cover there will be either abattery comparment or if it's 9 volt just two wire connector.Replace battery with same size type number and put cover back on.The battery is normally used to keep digital controls working,clock setback times etc. Hope this helps. Thanks
Nov 03, 2010 | Heating & Cooling
2004 YUKON XL DENALI, new throttle messed up delayed shift points
I recently had a low engine power on my 2003 Denali. The check engine light came on and I couldn't go above 40 mph. I took it in the next morning but by this time the check engine light had gone off. The mechanic had just recently seen the same problem in another Denali in which they changed the battery and had no problems since. I also decided to have them change out my battery and I have not had the problem since either. I would stay away from the dealership if I were you, and always get a second opinion. Most smaller shops wont charge for a diagnostic where the dealership will charge at least 80 just to tell you what might be wrong and that will only work if you have a warning light on at the time.
Jan 22, 2010 | GMC Yukon Denali Cars & Trucks
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!! Glad I'm not the only one... I don't know what to do! I have gotten brand new rechargeable batteries and instead of getting 250 shots, I only get like 20!
Dec 17, 2008 | Canon PowerShot A650 IS Digital Camera
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
Weird battery size
try code 00001 or 00002
May 04, 2008 | Directv RC23 Remote Control
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
Weird lines, characters, symbols etc.
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
Aug 17, 2007 | Texas Instruments TI-83 Plus Calculator
Directv RC32RFK Remote Control Logo
141 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
