Question about Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
I need a users manual for RL250GR/RL350 Electronic Self-Leveling Dual-Beam ROtary Laser
4 Suggested Answers
  • 2976 Answers
SOURCE: The red beam on my laser won't show outdoors?
Check for a lint ball or a small piece of debris in the lens area. The smallest piece of anything will knock the brightness down. New batteries would be the only other thing I would think of.
Posted on Jan 30, 2009
jyackle5
  • 8197 Answers
SOURCE: My stanley fatmax RL250GR laser
You can send the tool back to stanly and they will fix for free.
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=support.htm&LEFT=left_support.htm
Good Luck
Posted on Dec 05, 2010
  • 5 Answers
SOURCE: DEWALT LASER LEVEL SELF LEVELING THE LIGHT LASER
This is one of the cheeper lasers and is designed for predominantly indoor use this Dewalt DW087K unit has a visibility range of 14 yards. Although from experience they do drain the batteries quicker than you would think and cause the laser to be hard to see as well. Hope it works for you!!
Posted on May 31, 2011
Geo fennel fl200a-n calibration
ck to see that piviot bearing does not have and dust or junk in it and moves very easy , i use mine for drywall and i have to clean out piviot all the time to get proper level from it
Jul 06, 2014 | Stanley 77 156 RL100 Manual Leveling Dual...
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
I just put 3 new battery's in and leaser light will not come on.
Check for green corrosion on contacts and clean them A dab of WD40 on a Q tip will may help clean & improve the connection and provide extended protection.
Aug 25, 2013 | CST/Lasermark Self-Leveling Rotary Laser...
No laser beam how to fix
I would check the batterys first and if they are good, generally there is no way for an end user to fix a laser. I have talked to DeWalt in the past about this and been advised not to open it up. you can try to reset the laser and see if it reboots, sometimes they are so far out they won't turn the laser on.
Jan 31, 2011 | Stanley 77 156 RL100 Manual Leveling Dual...
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Replace glasses "broken"
I assume that you are talking about the laser enhancing glasses if so the part number is 603367-00 and they list for 14.52 if not let me know and I will dig deeper.
May 23, 2009 | Dewalt DW077KD 18 Volt Self Leveling...
Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level Logo
137 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
