Question about Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP
My 1996 10hp evinrude outboard motor won't go full speed unless you grab the motor and tilt it at a certain angle when running, only when in the water. Off the boat worrks like a champ. Took motor to shop & they couldn't find anything wrong, what is the problem?
    Problem Solver:
  • 19 Answers
Motor will fun up in revs out of water due to not having back pressure of water on the exhaust.
If it runs up fine at a angle and not if sitting in its normal place I would remove the carby then remove the float bowel (careful not to loose the little pin that hold the float in place) Once the bowel is removed and the carby is upside down then the top of the float (that now is on the bottom) will be even gap all the way across the carby.
I would bet it is a float level issue.
Posted on Aug 26, 2010
Testimonial: "We will find out!"
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
1996 70 hp johnson outboard, when put in reverse the motor lifts up when given a little speed and goes back down when you let off
If it does not have Power tilt, the tilt lever is either not in the run position or the mechanism is bound up. Look for a hook shaped that engages your tilt rod (the rod that sets the tilt angle in the 4 or 5 holes in your transom bracket. BTW no rod, no reverse lock.
Jun 26, 2015 | Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
Evinrude 50 HP outboard tilt and trim
sounds like the motor has give out . the clicking is probably the relays
Jun 14, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Logo
276 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
