Question about HP LaserJet 2300d Printer
Have HP Laserjet 2300d (Q2474A) printer that won't power on. Is their a fuse/circuit breaker on the power supply? How do I access Power Supply?
2 Suggested Answers
  • 8 Answers
SOURCE: Laserjet 2300d will not power up. Is there a fuse
first check the power cord and source.. if you have a spare cord, switch them, if this does not work turn on the printer and listen closely for any sounds, like a humming , if there is not sound then there is a fuse on the power supply, you can pull it and replace.
and if that does not solve the problem time to replace the power supply board.
Posted on Sep 11, 2010
Hp 2300dn. Why does double-sided printing blow the house fuse?
I have to say that this is one of the oddest questions I have been asked. The only real difference between single sided and duplex is that there is one solenoid and the drive motor reverses direction. Neither of these actions are directly connected to the power supply. Might be that there is a short. I would try a different outlet first.
Sep 13, 2015 | HP LaserJet 2300d Printer
What the cases for fuse in power supply
If fuse blow up there should be a reason. In most cases damaged/shorted component/s at its main power supply regulator section. Contact any service technicain. This is not a user reparable fault. Gopakumar Gopalan Google
Apr 22, 2014 | HP LaserJet P2055d Printer
Hp p1005 stopped working
Printer switching on?.Might be power supply failed, replace Power supply board.if you are tech guy..Open left,right & back doors. Check input fuse.. if fuse open replace with same rated fuse, give power, check.. if again fuse is open replace power supply board. if its OK wait few minutes & confirm.. fix it back..
Nov 28, 2011 | HP LASERJET P1005 Printer
My hp laserjet P2055d printer donot turn on.
Most of the cases, power supply goes bad, open check the input fuse, if its open check primary section of the power section, replace defective components.. if power supply good replace formatter..
Sep 12, 2011 | HP LaserJet P2055d Printer
Laserjet 2300d will not power up. Is there a fuse or circuit breaker on the power supply? How do I access the Power Supply?
Aug 23, 2010 | HP LaserJet 2300d Printer
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
At power up I get a 10.10.00 supply memory error.
check in back siode ther eis 1 plate for IC .
pull it after open screw .
then u see there RAM.
Refix it after clean dust from it and its slot.
If problem still arise then u have to change RAM.
Mar 26, 2009 | HP LaserJet 2300d Printer
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Feb 07, 2009 | HP LaserJet 2100 Printer
Hp lj 2300d
You either have a bad toner cartridge or a failed scanner assembly. Here's a free copy of the HP 2300 Service Manual to help you isolate it down. Check the troubleshooting section and it will give you a number of checks. The manual may mention a High Voltage Power Supply (HVPS) section on the DC Controller board but that would be highly unlikely. We have been servicing these since they were introduced and have never installed a DC Controller.
Here's the link:
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope that helps you. :)
Jul 17, 2008 | HP LaserJet 2300 Printer
HP LaserJet 2300d Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
