Radio Shack VGA PC Camera Webcam Logo
Posted on May 04, 2008
Webcam and headphone combo
I am not sure if I left off something when I was installing my webcam, but whenever I try to use it via skype or Msn it is not recognise. I can hear clearing with the headphone but not getting anything all from the webcam. Could you kindly assist me please.
It is a Dell flat screen with Vista operating System.
Thank
beba134
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 18, 2008
beba134
Contributor
Level 1:
Answers
Questions
0
Helped
49
Points
I need my cam to work??? how i doit
Well I have a msi laptop and the built in web isnt working and I checked if it was on and it says it is. But when I go to skpe or msn nothing happens and the little light beside it doesnt go on? I need...
You will have to set up or configure your webcam software to work with any chat program before you can broadcast.with it.
If it has a built in mic with the webcam -Make it your default mic.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Webcam
You both have to be in the same program to use your webcams.
You cannot hear her msn - this is probably a failing on her set up (mic)
She may have a laptop with a built in mic and she needs to nominate her webcam mic as default so that msn/skype software can locate it.
I suggest you both follow these instructions
Audio
TEST SPEAKERS
Restart computer
Configure to MSN
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Configure to Skype
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
2answers
Won't work with skype
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} YAHOO MESSENGER ?
Having proved your cam is working ,you can configure it to Yahoo Messenger.
COMPATIBILITY WITH YAHOO MESSENGER
Use Internet Explorer to visit this page to check compatibility and automatically download the latest webcam control
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'.
Messenger 10:- > Actions > More Actions > invite to view my webcam. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( +1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts may need to configure their connection the same as INTERNET CONNECTION above (Ignoring webcam connected) if they get a "webcam not connected" message
Sometimes you may have to broadcast the 'small image' option from the 'Webcam' menu on the top of your image frames. This happens when one of you is down on resources -its like sending a large photo by email - its quicker if you cut the size down
you can zoom up to 200% from the same menu when the webcam picture comes through
SKYPE ?
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER (MSN)
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
1helpful
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Other computers cant see my webcam images
YAHOO MESSENGER
CONFIGURE SOFTWARE
INTERNET CONNECTION
Webcam connected
TESTING
SET WEBCAM DEFAULT
PERMISSION OPTIONS
IN USE
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
SKYPE
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
1helpful
Some of my friends are on webcams driven by logitech and some on skype - can my logitech driven webcam access the skype friends?
Yes - no problem - you will have to download Skype - whenever you want to use a webcam in a new program you have to configure the webcam software to the chat program software
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
Click 'Save'
Click Save
1helpful
2answers
Question
CONFIGURE SOFTWARE to MSN Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly. The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted. Mine, I just unplug it from the USB and plug it back in to reboot the software. If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN Click 'Open Menu' From 'Tools; navigate to, and click, 'Audio and Video setup' Set your speakers Click 'Test' - if OK, move on. Set your mic as default Use the slider to set volume and test. Click 'Next' This takes you to the video setup Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
1helpful
I just downloaded skype.. how do I use a webcam with it? It is a SilverCrest 1.3 mpixel WC2130 webcam. brid
skype wil see you webcam and install it
try also msn with the webcam configuratie if thad works skype wil work also
2answers
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
1helpful
2answers
Toshiba Satellite A 215 - Webcam Doesn't Work
sir my all softwares r installed properly & im using vista stater. my web cam is not able 2 b detected
Top Radio Shack Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ExpressFiX
ExpressFiX
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
