Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
My cd rom dosnt read any disc so i carnt set up my printer.
    Scholar:
  • 122 Answers
Hello dondon, You can download the drivers and software for your printer here:
Post a reply if you have any further questions or please rate this solution if you found it helpful. Thanks!! Edward
Posted on Aug 23, 2010
The Burner does not read the discs.
try a firmware update and then if it still dosnt see the disc make sure if its old to check inside to see if the laser maybe out of set. and or a bad diode laser.
May 27, 2010 | Canon DW 100 DVD-RW Burner
Wont read the Lego Chess disk
This could be down to ur laser in ur cd-drive.. Could be many of things like Disc data corrupted etc etc. Sometimes if this happens i use a cd cleaner disc tht cleans the laser. These are very cheap.. But down to last resourt... Buy another version of the game. But if tht dosnt work then its your cd drive.
May 09, 2010 | LEGO interactive LEGO Chess for Windows
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I have tried to install my printer MP460 but it says it cannot find my disc what should i do
your cd or dvd rom might be going bad and cant read printer disc.mine did same thing read some disc and some disc it did not read dvd burner was going bad i replace my dvd burner and that fix my problem
Jul 18, 2009 | Canon PIXMA MP460 All-In-One InkJet...
CD ROM ONLY READS CERTAIN DISCS
uninstall the drivers on cd rom.then restart the pc the pc will reinstall them
Jan 10, 2009 | Sony Vaio CD (pcga-acd51/a) External...
Set up fax for MX3l0 canon
are you trying to instal the cd? if so i would try putting it inthe dvd writer combo as that can also read cds...it should autostart....usually itll tell you not to plug in the printer to the computer til the drivers are installed....try that an let me know :)
Sep 30, 2008 | Canon PIXMA MX310 All-In-One Printer
CANON OFFICE ALL IN ONE PIXMA-MX310 PRINTER SCANNER. SER.#ABAW88597,CD-ROM#U1.2 PURCHASED /06/15/08 WHEN I INSTALL THE CD-ROM FOR SET-UP PROCEDURE I GET A MESSAGE STATING MY OPERATING SYSTEM WILL NOT READ...
Have you tried downloading it from the manufacturer's website? In case you haven't here is the link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603#DownloadDetailAct
Jun 16, 2008 | Office Equipment & Supplies
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
Disc read error
check if your cd have scratches, this is one of the causes of disc error and you need to clean your cd rom you can use a cd cleaner just play it this cleans the lense o your cd rom
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
62 people viewed this question
old marine
old marine
