Question about Home
Hi I have had a Trevi Boost shower fitted , but there is no hot water and the higher the shower the less the water comes out?two plumbers have looked at it and cannot tell me why it does not work. I had a venturi shower for years and had no problem with it untill it just packed up?it was the older version and they no longer make them? I have a low water pressure so I bought this one as it is simular to the one I had. can you tell me why it does not work??? thankyou.
  • 374 Answers
SOURCE: only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Posted on Mar 11, 2009
SOURCE: Whirlpool 6600 24 inch dishwasher: low pressure,arms not spinning
Your water pump is blocked. You will either call a repair person or disable the top of the pumb (inside the dishwasher, bottom) and check the water input duck. It just might be just some food, etc.. that is blocking the input. But if you don't see anything then it will be futher inside and will need to be removed and cleaned. BIG pain...
Best of luck. BTW, I have the exact same problem but mine is further inside so I have to remove the whole dang pump, arggggggg.
Rick
Posted on Apr 27, 2009
  • 9 Answers
SOURCE: Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Posted on Aug 28, 2009
  • 122 Answers
SOURCE: low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Posted on Jan 30, 2010
  • 50 Answers
SOURCE: We have a Maxx shower SA9592-02. The water comes
take a philips screw driver and take the screw out and flip the hot cold handle that should fix your problem
Posted on Mar 12, 2010
Hi, is there a way to make the hot water hotter in a 2016 Jayco Journey. The water is just hot enough for showering but not hot enough to wash the dishes.
remove the unit that mixes the hot and cold water at the hot water system to prevent scalding of people
it is fitted there by law but unfortunately the plumbers who fit it are not willing to fit it where it is supposed to be fitted ( baths , showers and hand basin taps and lines )
better and cheaper to fit just one than several
it is not required for sinks and dishwasher and washing machines lines
anyway the human hand cannot stand water over 75 c as that when burns occur so having hotter means that you have to add cold to be able to put your hands in the water and that sort of defeats the purpose of having hotter water
Apr 05, 2017 | Home
Where can I purchase a remote control for a Trevi Logical Shower?
If you cannot locate a remote control have a plumber command and we can figure the plumbing two valve so your body wash your rainshower every will work without remote is just a gimmick
Aug 09, 2014 | Home
Navien combi boiler
call in a plumber. it sounds like it is malfunctioning.
Mar 18, 2014 | Taco SR503-4 3 Zone Switching Relay
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Jul 08, 2009 | Water Pik Wall Mount Shower Head
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
No cold water, Only hot water in showers.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Jun 01, 2009 | Danze & Single Handle Tub And Shower...
No cold water comes out of one of our bathroom shower
Obviously your plumber when they were building the home hooked up hot water lines to both faucets and never hooked up a cold water line.
Jun 01, 2009 | Moen Showhouse Waterhill One Handle Tub...
Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil
www.redring.co.uk
http://www.protimbathrooms.ie/downloads/pdf/RedringBrochure.pdf Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
http://www.applied-energy.com/clientfiles/File/manuals/redring/Powerstream%20Instructions.pdf
Dec 28, 2008 | Home
Home Logo
83 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
