Question about Carrier 38CKC036 Air Conditioner
Compresser is shorted out across the fields. I want to comfirm the compresser size before I replace it.
  • Carrier Master
  • 43,501 Answers
You need a niminal 3 ton compressor...the "36" in the model number gives you the 3 ton rating...36000 BTU @ 12000 BTU/ton = 3 ton...
So you need a 3 ton 240 volt single phase compressor...
heatman101
Posted on Aug 23, 2010
How do I check the compressor
What I would do first which is very simple is leave the fridge on for a bout 20 min. Unplug it, pull it out, pull the bottom cover off and place your hand on the compresser, if it is very hot, compresser is pooped. If it is not warm at all then I would first check the thermostat. If the thermostat is closing properly then you can check for power at the compresser by pulling the little black cover off of where the wires enter the compresser. If there is voltage there 120v then unplug the fridge and pull the connectors off of the terminals on the compresser, remembering where they go of corse. Between two of the terminals you should get a low resistance. Say 1.5 and through another set you should get a higher one. Say 4.6 then through the last test you should get those two nembers added up 6.1 if your meter says OL at any time that means you have an open winding and the compresser is done for. If your numbers do not add up then you may have a shorted winding and your compresser is done for. Good luck
Sep 06, 2012 | KitchenAid Superba Architect KSCS25INSS...
I put a new compresser on my 1994 gmc pickup ichange it for anothe rnew compresser it does the same thing. what could be the problem
need more info.....To start i need the year, make, modle and motor size. What is the Problem ??
Jul 05, 2011 | 1994 GMC Sierra
The air conditioner cooled on the driver's side and heated on the passenger's side. Took it to the place where they replaced a new gm compresser 2 years ago and they tested and stated that it is an...
If the compressor cycles on and off very fast, you most likely are low on coolant and it needs recharged.
The cigarette lighter light is not on the same line as the lighter itself. Check your fuses.
You could have a problem with the damper in the vent system, giving you different temperatures on either side of the vehicle.
Jun 09, 2010 | 1998 Cadillac DeVille
Wont to get rid of aircondition compresser what
you could try and measure around all the pulys and figure out what size belt is needed or try calling a ford dealer or some local auto parts store, they might be able to pull up a belt size/part number for a engien that is not running a a/c compressor.
Mar 25, 2010 | 2001 Ford Taurus
2007 hyundai accent...a/c and blown fuse, electrical short
check hor wire going to compresser make sure no short to ground if compresser uesd a speed senser in compressr check it also
Mar 14, 2010 | 2007 Hyundai Sonata Limited Sedan
Can you by pass the a/c compresser by using a
yes you can, its a different size belt.
Nov 06, 2009 | 2002 Saturn L-Series
How do I replace the a/c clutch on 1998 grand Marquis
The AC clutch can be replaced but the logic for doing so isn't good. A remanufactured Compresser with clutch cost very little mare and the compresser being bad is very likly to be the cause of the bad clutch. Once you installed the clutch its yours and you'll lose its cost if you still need a compresser. Change the compresser it's not worth the difference in cost
Aug 23, 2009 | 1998 Mercury Grand Marquis
Air conditionin gunit keeps tripping breaker. A/C is carrier 5 years old compressor?
Sounds like you have a grounded compresser with a direct short.To know for sure you can disconnect the compresser and then flip the breaker and see if it still trips.If it still does check the motor,but this is most likley the compresser sorry.Carrier does have a 5 yr warranty so hurry and call someone it could still be in warranty!
Jul 17, 2009 | Heating & Cooling
AC compresser throws breaker
It could be a few things..
Might be the compressor going out ;o(
But could be the capacitor..
Its about a 4 inch part with 3 wire conectors at the top.. Could be round or oval and is usually metal & looks like a can..
This part replacement fixes problems in allot of cases & shouldnt cost to much.. If it is not the problem - at leaste that part is eliminated... Good luck..
Jul 09, 2009 | Heating & Cooling
Freezer side compresser short cycling sounds like compresser is laboring pressures are at 45.ls 150/hs before shutting down and re trying
Assuming you have checked that the defrost system and fans are working correctly. I suspect that you have a blockage in the refrigeration system. You need to flush and vacuum and replace the reciever drier.
Mar 11, 2009 | Freezers
Carrier 38CKC036 Air Conditioner Logo
96 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
