Question about Humminbird 140c Fishin' Buddy
My portable hummingbird fish finder runs for about 30 seconds and then fades out.. fresh batteries and still the same issue. Hummingbird 140 c portable fishfinder.
5 Suggested Answers
Editor925
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
gopakumarg43
  • 74243 Answers
SOURCE: THE UNIT WILL POWER UP
Hello
Just reset the unit to its factory settings first and see whether it helps you. To get it to its factory reset:
1# Highlight Restore Defaults on the Setup menu
2# Use the RIGHT 4-Way Cursor Control key to initiate restoring defaults.
3# The Confirm dialog box will appear. To reset the defaults, press the RIGHT
Cursor key once more. To cancel Restore Defaults, press the LEFT Cursor key.
Before doing this rest option make sure that the battery voltage at the power connector is at least 10 Volts with device on load. Correct any known problems incuding removing corrosion from the battery terminals or wiring , or actually replacing the battery if necessary. Anyway, the voltage at the supply terminal to the device should be more han or equal to 10VDC, at device in ON condition. OK.
Posted on Aug 24, 2011
  • 111 Answers
SOURCE: My hummingbird rf15 smartcast fish finder has
The Smartcast system uses the wireless version of a simple transducer and thermometer to locate fish, show structure and water temperature. From your description, it sounds like the transducer portion of the Smartcast device has stopped working.
Transducers are both simple and complex, sturdy and delicate. Here is a Science Minute: A fish finder electrical signal is sent to the transducer. The electrical signal to energize the transducer crystal is generated by an amplifier. The energized crystal reverberates at a particular frequency, to convert the electrical signal into mechanical acoustic or sound energy. The acoustic energy or sound waves causes oscillation of the water molecules through which the sound travels. The sound is pulsed out in a defined beam. These do not travel out in a straight line but in a wave pattern. The acoustic pulse travels through the water at a rate of approximately 4800 ft (1500m) per second in saltwater and 4920 ft/sec in fresh water.
The problem is that the crystal in all transducers (permanent mount, thru-hull mount and castable) is delicate. It is a crystal. Unfortunately the warranty on most of these is six months, and unless yours is newer than that, you may need to buy a replacement castable. The handheld unit should still work. While I think the idea of knowing what is "over there" is a good one for shore fishing, I haven't bought these systems because I could never get over the idea that repetitive casting of a crystal, no matter how well-housed, was a good idea. Good luck.
Posted on Sep 27, 2011
tow2000_au
  • 69 Answers
SOURCE: I have a hummingbird 361 I it fails to register depth at speed and mark fish at all
Craig you dont say if it detects while stationary, however I did find with mine it was as simple as change the angle of the transducer by one notch
Posted on Sep 28, 2012
Hummingbird 140c power problem
I am having an issue getting my brandnew 140 C to turn on. Fresh batteries... Called customer service, they want me to send it in. Ill update you when I find out what the issue was...
Mar 28, 2013 | Humminbird 140c Fishin' Buddy
Speed senser on Hummingbird does not work.
You might want to post this question in a different section. This is the computer games section.
Jul 09, 2012 | Hummingbird Computers & Internet
Is there a free downloadable manual for a Humminbird LCR 4000 Fish finder?
type in hummingbird lcr 4000 fish finder manual pdf. it works for anything you want
Nov 04, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
Depth finder comes on then goes off
It sounds like some power saver feature on the battery or in the unit. Check with hummingbird, they should have an 800#.
May 12, 2009 | Boating
Insructions for piranah fish finder at home,
Go to this webpage and click on the link of the manual of you finder and it will open up your manual.
http://www.humminbird.com/support/FAQ.aspx?faqid=72
Dec 29, 2008 | Humminbird Smartcast Rf 35 Dual Display...
Humminbird 140c Fishin' Buddy Logo
65 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
