Question about Timex 27191 Wristwatch
INDIGLO watch setting procedure - Timex 27191 Wristwatch
  • 1 more comment
  • larzgirl Nov 06, 2008
    How do you change the time from Military to regular.
  • Anonymous Feb 24, 2009
    I cannot set the time. Tom
  • Anonymous Mar 03, 2009
    i cannot get the day of the week and the date to match such as Tue. 3. Need some help there. This is a basic watch wr 30M by timex indiglo. I threw away the instructions by mistake can someone help me please. My husband has dementia and needs his watch. Any help will be deeply appreciated. Thanks in advance.
How to set the time from military to reg
Posted on Nov 05, 2008
How to set the time on a chronograph watch acqua indiglo
Posted on Mar 20, 2009
Indiglo time set
Posted on Apr 05, 2009
4 Suggested Answers
SOURCE: Acqua Indiglo watch
Can't understand instructions
Posted on Aug 31, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
escapement
  • 2334 Answers
SOURCE: I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Posted on Mar 28, 2010
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    Set time1440sports
    Buttons are numbered as followed:
    Start/Stop is button 1
    Lap/Rst is button 2
    Indiglo is button 3
    Mode is button 4
    a) Press 4 to select "TIME" mode
    b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
    c) Press 1 to reset digits to 00.
    d) Press 4. Minute digits blink
    e) Press 1 to set minutes.
    f) Press 4. Hour digits blink.
    g) Press 1 to set hours.
    h) Follow same patter to set day of month, month, etc...
    i) Press 2 at any time to retain set values and exit procedure
    Nov 16, 2011 | Watches
    I have a ladies timex indiglo watch that I was able to get the back off and replace the battery but now I can NOT get the back on again. It doesnt seem to have any grooves on it. It seems as if it would...
    I have an old Timberland Indiglo watch in which I had the same problem. I folded up a paper towel for padding and I used two sets of pliers, one to hold one side of the watch while I used the other set of pliers to snap the back cover closed. It took two seconds to do.
    Sep 10, 2010 | Timex 27191 Wristwatch
    Mar 28, 2010 | Timex Watches
    I have a timex indiglo, mens watch, A christmas gift, and am having problems setting the day and date. The stem appears to have only one setting, notch
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMES watch manuals. Rate me, please
    Mar 09, 2010 | Timex Indiglo Watch
    Alarm on timex indiglo won't turn off
    It's just a cheap watch, one hit with a hammer and the alarm stopped.
    Jan 18, 2010 | Timex Expedition 84601 Wristwatch
    Hope this tip helps
    R/
    David
    Dec 06, 2009 | Timex 27191 Wristwatch
    Acqua Indiglo watch
    Aug 31, 2008 | Watches
    Timex Watch
    While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
    Press the mode or bottom left button until the hour digits start to flash.
    Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
    Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
    Timex 27191 Wristwatch Logo
    2,326 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    David Ellis Rhea
    Are you a Timex Watch Expert? Answer questions, earn points and help others
