RUUD AIR CONDITIONER WHAT TON IS THIS UNIT THE COMPRESSOR WENT OUT AND I FOUND A 3 TON COMPRESSOR BUT NOT SURE IF IT WILL WORK FOR MY UNIT?
  • 43,501 Answers
Look in the model number for a pair of numbers like 18, 24, 36, 48 ,60... these are the btu output of the unit... then divide that number by 12 to get the tonnage of the unit... for that compressor to work for you the unit should have a "36" in the model number...
heatman101
Posted on Aug 23, 2010
  • rclark228 Aug 23, 2010
    Thank you so much for the information, my model number has a 48 so it's a 4 ton :(
Ruud 5 Ton UAKA Condensor fan running but compressor won't start. Internal thermal overload cycle.
Have you checked the wiring going to the compressor to make
sure it is not melted? Next, are you
able to put your hand on the top of the compressor? Check to see if it is hot or cold. You might have a bad run capacitor so let the
unit turn on, wait about 5 minutes, turn the unit off, and then tell me if the compressor
is hot or cold to the touch. Next, are
you comfortable with a meter?
Oct 17, 2013 | Ruud Matching Split Air Conditioner
I have a 5 TON Ruud split unit air conditioner.The Compressor was replaced last year.Now the unit works well for about 15 minutes and then stops cooling. Thermostat says,"In Recovery". What can I do to...
May be due to improper refrigerant pressure; I would have it checked.
'Recovery' is normally provided to allow high- and low-side pressures to return to a safe range before the unit is allowed to cycle again and yours is doing it way too soon.
Aug 07, 2010 | Ruud Central System Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Ruud UAKA-037JAZ A/C How do i determine how many ton unit it is?
its a 3 ton i went to ruud and looked it up for you.
Jul 31, 2009 | Heating & Cooling
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
A/C Compressor Problem 3 Ton
IF the compressor is under warranty they should not charge you anything. it is according to what type of warranty you purchased, If the business is gone, i don't know much of what you can do other than calling ruud directly. Most likely the unit is past the warranty. Call ruud to be sure.
Jul 12, 2009 | Heating & Cooling
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
3 Ton Ruud compressor
Is the unit over five years old? If so it is a fair price for conpressor, parts, labor and refrigerant. Have him give you a firm price. If it is an older unit, say over 10 years, and you have the money replace the complete system
Jun 15, 2009 | Ruud Handle Air Conditioner
Need to replace 3 ton compressor
Depending on age of the unit. The compressor amy under warranty. The replacement is something that should be done by a service tech. You have 3,5 ton unit Rus
Jun 14, 2009 | Ruud UAKA042 Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
