Question about Sharp LC-19SB25U 19 in. LCD HDTV
No audio unless audio out from cable box is connected to audio in on TV
    President:
  • 2,047 Answers
Thats how it is supposed to work. The tv cannot produce sound unless sound is being fed into it. The audio out from the cable box supplies this sound to the unit through the audio in on the tv set.
Hope this solution has been helpful?
Posted on Aug 23, 2010
Install home theater insignia
How are you connecting the devices?
If you have used the cable box audio out (RCA) to the audio in (the ones just right of the digital coax audio out and the S-video out) on the home theater system, make sure that you have selected the correct Source. (Use the Source button on the front of the system to select AV1 or AV2. This toggles between AV1, AV2, tuner and DVD. It's the right-most button below the display screen. Alternatively, use the Tuner/Aux button (second from the bottom on the left) on the remote.) Note with this connection, the video source cable should go to the TV directly. Unless it is a composite video signal. Then connect the RCA video out (REC out). Make sure that the audio digital output is off. Press Setup/Exit (just above and to the right of the arrow keys) on the remote. Go to the audio menu (press the left arrow key twice) and press OK. The first item in the list is the digital output and should be blank unless you are feeding the audio to another system.
Next try a different audio cable and check that your speaker wires are all connected. Check that the cable box is getting power and a signal from the provider. Connect it to the TV to recheck. If it isn't, make sure that the cables didn't come loose on the box while you were making the connections to add the system.
If you have a newer cable box with HDMI or digital audio out, these most be connected differently. A digital to analog audio converter will work with the second option. For an HDMI connection, connect that cable to the TV, then connect the TVs analog audio out to the NS-H2002. Then go to the Audio menu of the TV and turn on the external audio and turn off the internal speakers. (If your TV has a headphone jack as the only analog out, then this step may not be needed. However, you'll need a 3.5 mm to RCA stereo cable or adapter.)
Check if the audio works with another source (like a DVD). If another external source works, then it's the cable box or the connections to it. If no external sources work but you can here a DVD play, it's probably the input jacks on the system.
I hope this helps. Please add a comment with more information about the cable box outputs and the TVs inputs and outputs if you need additional assistance.
May 22, 2012 | Insignia NS-H2002 Theater System
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
What audio cable is needed to connect Panasonic Viera to SABT230
Have you referred to the manuals?
It all depends on which way you intend audio to GO.
Consider this: Is the TV really a SOURCE of audio or does the program audio come from elsewhere, like a Cable Box with REAL digital audio capabilities? THAT is where you want the SABT230 to get the TV-related audio, on an optical cable.
Unless your TV has a speaker complement comparable to the SABT230, the TV only NEEDS video and maybe basic audio (from the Cable Box?) for those times you just want to have the TV on for casual watching, like news. AV OUT HDMI can carry video and (unnecessary) high-end audio to the TV from the SABT230, while standard RCA stereo cables can carry the 'normal' audio from the Cable Box to the TV. In any serious viewing you would probbaly mute the TV speakers and use the SABT230 for listening.
Mar 05, 2011 | Panasonic SCBT230 Theater System
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
We have a cable box, rca reciever, a dvd and a non digital tv. Does the reciever need input from cable box, dvd and tv?? is red, yellow and white audio/video enough to connect or is a S-cable or optical...
From your cable box, send "optical" to the receiver. From the DVD send "coaxial digital" (looks like one rca cable" if your receiver has it, if not, optical is fine as well. There is no reason to send audio from the TV to the receiver unless you are using an "off-air antenna". If you want to have audio from the cable box to the TV for listening to TV speakers only, send an audio video cable (red/white/yellow) direct to TV. If you need more help just post a comment and I can help you some more.
Jul 07, 2009 | RCA RT2660R Receiver
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
Sharp LC-19SB25U 19 in. LCD HDTV Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
