Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Clogged with detergent that is congealed - GE 24 in. Profile PDW9880JSS Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 23, 2010
How do I remove the detergent tank, so I can empty and rinse it?
You have to remove the outer coverings to get down to the tank or if you can get to the bottom end of the pressure hose, you may be able to slip off he plastic supply hose to the tank and back lush up the hose and rinse the tank out. Never leave detergent in the tank, it will congeal over time and block the line.
May 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
I have a GE profile PDW9980N20SS dishwasher that has a smart dispense feature to auto dispense the detergent. The manual warns to not interchange enzyme based and chlorine based detergents or it will...
Hello, ajswave
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
May 01, 2011 | Maytag Dishwasher
How do I purge congealed gel detergent from the Smart Dispense bulk dispenser? I've scooped out all that I can and added water to dilute the remaining, but it doesn't want to empty during cleaning cycles....
Part of the solution is on the GE website: http://www.geappliances.com/search/fast/infobase/10010832.htm
But first you must remove or mash the gelled detergent into very small pieces so it can pass through the pump and outlet. You must clean out most of the gelled detergent down in the door going towards the pump and the outlet at the base of the door. You can disassemble the door, or I used a length of 3/8" soft plastic tubing pushed down into the detergent cavity repeatedly to break up and pull the chunks up to the fill door where I could remove or mash them. You may also need to this between the first run of the procedure and the second. You may need to do the purge filling the dispenser with water (I used hot - 120F) more than the once in the procedure.
Jun 25, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Clothes come out with an oder
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2009 | GE Profile Prodigy WPSE4200A
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Soap has congealled
Pour half a cup of white vinegar straight into the bottom of the machine and run it through a fast wash. You may need to do this a couple of times?
Jun 16, 2009 | GE Profile PDW8600J Built-in Dishwasher
Bad leak
Your first option before anything else is to remove the dispenser tray entirely and clean it thoroughly.
Also clean inside where the fits before replacing.
Quite often there is a build up of old fluids or powders that have congealed and blocked up the inside.
Good luck and thanks for using FixYa.
Mike.
Mar 02, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
How do I make sure the dispenser is completly empty?
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Jul 21, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
174 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
