Question about Microwave Ovens
Won't heat food. Cracking/popping noise at times. Bad electrical smell this time & EVERYTING got HOT on the microwave (not the food) the microwave its self. It will be 2 yrs. old next month. Should I pay for repair or buy a new one? If I should get a new one, which one should I buy? Thank you for your help. Ken Tillman
  • 5,911 Answers
The symptoms you describe are common signs of a failed (or failing) magnetron. The magnetron is the heart of the microwave oven and is the component that generates the RF energey required to heat food. Using the oven in a prolonged state with a magnetron that isn't firing properly can cause damage to the wave guide assembly as well. If this problem just occurred, you may want to go to any of the following websites and search their prices for what a new magnetron may cost:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer competitive pricing, so shop and compare. The first three websites have helpful exploded view parts diagrams to assist you with locating and properly identifying any parts you may need.
Magnetron prices will vary between manufacturers and model numbers. Some prices are as low as $30 or $40, while others are as high as $200. The cost of replacement parts, alone, can determine whether or not the appliance is worth repairing. If you call a repairman, there will be an added cost of labor. If you wish to perform this repair yourself, please post back and let me know BEFORE you attempt to disassemble a microwave oven. There are certain safety precautions that you need to know prior to servicing anything inside.
NOTE: Most appliances come with a one year limited warranty from the manufacturer. However, some manufacturers have extended warranties on certain parts. You may take a look at any warranty information that may have come with the appliance to see if there's anything the manufacturer may cover.
Posted on Aug 23, 2010
Microwave blew house outlet circuit breaker, what is wrong
you have a short it could be anything would need to be diagnosed and dont plug back in and try to use again potential fire hazard --compare replacement cost to repair cost
Sep 09, 2016 | Microwave Ovens
Microwave won't heat
you have a power diode defective, high capacitor or Magnetron, test it for open with DVOM OR VOM , or better consult the qualified tech, Because this involve high voltage.
God bless you
Jul 10, 2012 | Frigidaire GLMV168K Microwave Oven
Ge microwave digial dispaly works but nothing heats-
in 99% of casses its a burned out magnatron they can be expensive to replace but it depends on how much the microwave is worth
Jun 19, 2010 | General Electric Microwave Oven
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
Food not heated in mocrowave
I'd say the actual microwave generator has gone bad.
Jun 05, 2009 | GE XL1800 1100 Watts Microwave Oven
My Panasonic Microwave Genius 1300W will not heat up the food and the rotate dish spins and the sensor reheat will not heat up the food. Nor cook Pop Corn when pressing the buttons to 2:00 cook time. I...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 14, 2009 | Panasonic NN-S960WA Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
GE microwave oven groans then turns off
Can you give more details, such as when and how it "turns off" as well as the brand and model?
Happy to help.
Oct 22, 2007 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
