Question about HP G70-246US Notebook
Laptop will not start up at all. The led next to the power jack lights blue nothing happins when i hit power.
  • pattonthomps Aug 24, 2010
    I HAVE TRIED THAT. NO OTHER LIGHTS COME ON. THE COMPUTER WAS PLUGED IN THE NIGHT BEFORE SO THE BATTERY WAS CHARGED. IS THERE AN INTERAL FUSE OR RESET ?
    Problem Solver:
  • 16 Answers
When you press the Power button do any of the lights Flash or blink?
1.May be try removing the power adapter and battery, press and hold the power button for 30 seconds and try again.
2. Connect the power adapter with no battery
Posted on Aug 24, 2010
  • GLACIOU5 Aug 25, 2010
    Looks like it may be a hardware failure, you may have to get it repaired.
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
My HP Compaq nc8000 will not start up correctly. When i hit the power button, only one green LED comes for a few seconds, then a yellow LED (which is the charge light) it sounds like the laptop is powering...
Check it is powering laptop,if not the jack has bad connection and not connecting to mainboard constantly,
Dobt thats what is happening in your case but need to rule it out for next step.
Remove the battery then try ac adaptor on its own.
Next try removing ram,insert one stick only,next sub it with other stick only,if still no good remove hard drive,you are attempting to get bios start screen to show up,if still no good you may be looking at mainboard power regulator ic fails,which are a real problem on some compaq models this also damages other components on the mainboard(google search will reveal what im on about)
Dont remember offhand but if its the type that has common mainboard fail its not worth repairing as the new boards always fail eventually due to same problem.
There are also light error codes in the back of the manual and available online to diagnose this by the type of lights showing up.
Feb 17, 2011 | HP Compaq Business nc8000 Notebook
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jan 19, 2011 | HP Pavilion dv6000z Notebook
When you press the start button nothing happen not light or start up
First remove the battery and put it back in, you want to make sure it has a good connection.
Next you want to check the power adapter. If it has a built in LED light, it should turn green when plugged into the wall. If it does have a light and the light will not turn on or it blinks, replace the adapter. Next, plug the adapter into the computer, does the LED light change? Example, the LED light was a solid green, when you plug it into the computer it blinks. If the light does something along those lines, then there is a problem with the laptop itself.
If the power adapter does not have an LED light, then you need to use a Multimeter to check if the adapter outputs the right amount of power...which should be around 12 volts.
If the battery and power adapter pass the tests, then you are looking at a hardware issue in the laptop. From your description of the problem, I would guess the motherboard has died or that the charging jack on the motherboard came loose and needs to be replaced or re-soldered.
Two things that would stop the light from coming on, No Power or Motherboard is broken.
May 02, 2010 | Toshiba Satellite M45-S169 Notebook
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
When connected to mains adapter the 2 left side LEDs on the front of the computer {standby+mains connected]start to flash and doesnt charg
This happens when the battery will not hold a charge. You will need a replacement battery if you want that light to go away.
If the battery has not been like that too long
put in a plastic bag and freeze overnight
let thaw until room temp
insert battery
plug in jack
do not power on laptop
let charge for1 hour
then try
Apr 15, 2009 | HP Pavilion dv8000z Notebook
Won't Power Up - A135-S4427
power surge only affects the ac adapter... replacing it might do the trick... and/or have it repaired by a certified electronics technician...
Aug 27, 2008 | Toshiba Satellite A135 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
See all HP G70-246US Notebook Questions
HP G70-246US Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
