Question about Dishwashers
Hi I've got a diplomat dishwasher but the tablet keeps dropping into the cutlery department and is not dissolving I've tried putting it on the hottest wash puttng the tablet in one of the trays but nothing is working the pots are getting slightly cleaned but are still dirty what do you suggest?
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 23, 2010
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
My diplomat dishwasher is not dissolving the tablets even on a hot temperature, what can i do?
Check if the circulating pump is actually working - are the dishes being cleaned at all ? If not - check pump for operation and replace if faulty.
If tablets are still stuck in a compartment - replace operating mechanism for tablet drawer, or - cheaper - put tablets in with the cutlery instead.
Aug 20, 2010 | Dishwashers
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Tablet not fully dissolving during washing cycle and the cutlery and glasses are left stained
How do I remove the filter on a CONCEPT II dishwasher? It is full with stuff.
Mar 30, 2008 | Dishwashers
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Dishwashers Logo
319 people viewed this question
Top Dishwashers Experts
